Well I had the PCM redone, put it back in, same problem. They sent me another PCM, and same code, so I ruled out PCM. It is at my buddy's Corvette store, and his tech has it apart. He only has 02 shop manual that shows red and blue proms. My 04 has blue and green proms?
Thanks Lucky! This problem is going to be the death of me. I can only assume it is in the wiring from the PCM to the fuse block under the hood. It had probably 10 nicked or chaffed wires on the harness near the PCM.
Common area to chaff. Have him inspect the vacuum lines while in the area. After repairs, make sure the wire harness is clad to protect it. Good luck...
