Rearend Gear Oil
Old Aug 20, 2010 | 08:03 PM
Moab's Avatar
Moab
Default Rearend Gear Oil
Well I am about to do an oil change and also want to change the tranny fluid and rearend gear oil, I've already bought the Mobil 1 for the engine and the trans, but can't find Mobil 1, Amsoil or Redline gear oil anywhere in town here.
The closest I can find is Quaker State full synthetic, which doesn't seem to have the limited slip additive in it. I use this in my truck with no issues, but would prefer something better and with the limited slip additive in it already.
So does any of the vendors sell online here? or for the Canadian guys, any recommendations on where to get a good oil?
Thanks,
Jeff
Old Aug 21, 2010 | 11:48 AM
Moab's Avatar
Moab
BUMP^^^^
Any suggestions on where to get some Mobil 1, Amsoil, or Royal Purple online?
Or is the quaker state stuff good enough with some NAPA limited slip additive? CRC brand in squeeze tube.
Old Aug 21, 2010 | 11:51 AM
dbaker's Avatar
dbaker
I use & recommend Amsoil Severe Gear 75-90.I use it in my 02Z and 03 S2K.
Check out this guy....
http://www.c66racing-synthetics.com/
\db2
Carolina
Old Aug 21, 2010 | 12:20 PM
Moab's Avatar
Moab
do you have to add extra additive to the severe gear? or just fill and go?
Old Aug 21, 2010 | 01:07 PM
MR Turco's Avatar
MR Turco
Fill and go, shouldn't need the additive unless you hear the chirps in turns.
I just bought this stuff as well, will be putting it in soon.
Old Aug 21, 2010 | 01:16 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
A lot of folks love the Amsoil, I use RedLine. If you can't find either where you live, try Summit Racing...
Old Aug 22, 2010 | 09:12 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
\db2
Carolina
Thanks!
Moab,
Here is my recommendation for the C5 diff:
My recommendation for the C6 to cure the diff clutch pack chatter:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
AMSOIL Hand Pump (Product Code G2039)
Note that the Severe Gear 75w90 does come with friction modifier and C5s don't require additional modifier to prevent diff chatter. I run this fluid in my SCCA T1 02 Z06 which has a stock drivetrain and haven't ever lost a diff in something like 30+ races.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Aug 22, 2010 | 10:09 AM
johnson-rod's Avatar
johnson-rod
I put Amsoil in both transmission and differential several years ago. No problems. ATD made the transmission shift smoother. (M6) No chattering from the rear.
This is a DD with 73K on it.
Old Aug 22, 2010 | 10:37 AM
rws.1's Avatar
rws.1
The Quaker Synthetic will be fine as long as you ad the posi or limited slip additive. You can get the GM brand at your dealer, but the aftermarket ones at most auto parts stores are fine,
Add the 4 oz of slip additive first , then the gear oil
Old Aug 22, 2010 | 11:45 AM
lbarnard's Avatar
lbarnard
Torco Gear Oil 75-90w + 1 bottle GM limited slip
Old Aug 23, 2010 | 06:54 AM
Moab's Avatar
Moab
thanks guys!
Does the diff take 2 or 3 quarts of fluid?
Old Aug 23, 2010 | 05:22 PM
T5Mika's Avatar
T5Mika
GM fluid works the best. I used the new part number 88862624 that includes the posi additive already. The chatter and chirps are gone and the LSD function is perfect. 2 quarts, but it's handy to have 3 because it's hard to squeeze in much more than half of a bottle (unless you use a pump or something).
Old Aug 23, 2010 | 11:11 PM
robsc501's Avatar
robsc501
Hi There,
Use the amsoil severe gear.Do a google to find your local dealer.Order the amsoil hand pump p/n g-2039 $ 11.76. A lot better than the squeeze type bottles & no mess. 2qts for the differential.(1.69 qts. capacity.
robsc501
Old Aug 24, 2010 | 10:41 AM
00Corvette's Avatar
00Corvette
whatever you use make sure it either has the limited slip additive or you get the 4 ozs or whatever of the GM recommended limited slip mix..
The amsoil, redline and mobil one "LS" all have it. Mobil is obviously easiest to fine, Amsoil is imo the best oils/lubes on the planet
To Rearend Gear Oil
