Any info where I can buy a new or in good condition trans plug would be appreciated. The only way I can get that part from the stealership is to buy the pan AND the plug which is around $160+.
Cumnhot, now where have I heard that phrase before?
If you can't find what you want from someone here, and you know the bolt specs, try here: http://www.mcmaster.com/#o-ring-bolts/=8j814d They have a gazillion bolts. If you don't know the specs, maybe someone can get them for you. Good luck in your search.
