I'm in the process of changing my f45 shocks with C6 Z06 shocks.
I was looking around and noticed the right spring adjuster bolt where it
Contact the lower control arm the rubber is coming apart and looks like there are two washers that have slipped out from between the adjuster pad and lower control arm.
Can I slip the washer back between the pad and control arm or do I need parts?
