hard starting problem
Old Aug 23, 2010 | 05:15 PM
Riveria's Avatar
Riveria
Default hard starting problem
Just got my 1st vette in 20 years. 99 6spd with 28k on it...what a car! I have a problem starting when it sits for more than a day or two. It cranks a lot b4 starting. Once I use it daily, no problems. I suspect the fuel pressure is bleeding down. Car has no problems at full throttle or any normal acceleration. Does each injector have an individual check valve, or is there a main check valve somewhere on the fuel rail? Thanks for any help............
Old Aug 23, 2010 | 05:31 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Connect a fuel pressure gauge to the fitting at the front of the driver's side fuel rail. Its under the coil cover.
Old Aug 23, 2010 | 06:58 PM
dougbfresh's Avatar
dougbfresh
Check the pressure BEFORE you start it and then after it starts. The pressure should hold in the system for quite some time after you shut it off, if it bleeds off quickly you have a leaky injector(s) or the pump may be getting weak.
Old Aug 23, 2010 | 10:55 PM
Riveria's Avatar
Riveria
thanks.......
To hard starting problem
