uneven exhaust tips
Old Aug 23, 2010 | 10:04 PM
robsc501's Avatar
robsc501
Default uneven exhaust tips
Hi there,
I,am trying to figure out a fix on a friends quad cruiser w/ x pipe installed.
The drivers side tips are protuding 3/4" from the rear of the body. The pass. side tip is protuding 1 3/4" from the rear .I checked the measurement from the tranny bracket.This is whats on his car 30 1/2" on the drivers & 29 1/4" on the pass. Should be 31 1/2" & 30" the quad cruiser & the Corsa sytem are the same. My question is where to start to correct this situation? I want to make the correction per the instructions & recut at the h pipe & make the cut from the front of the bracket 31 1/2" & 30" on the pass. side.(Is this the right place to start?) What does this measurement insure or represent? I think that this insures that the tips come out flush with body.Not positive though.
Thanks for any advice
robsc501
Old Aug 24, 2010 | 12:18 PM
robsc501's Avatar
robsc501
Moderator please delete the above post.
robsc501
