Fuel Level Sensor
Old Aug 25, 2010 | 04:36 AM
99MALLETT396's Avatar
99MALLETT396
Default Fuel Level Sensor
Hello guys,
A few months back i changed the fuel pump in my 04Z and while at it i changed the fuel level sensor as well. Now the fuel gauge only reads half full when i have a full tank and dead empty when i have 1/2 tank and i get the low fuel level and check gauges light too.
The reason i changed the old level sensor cause i damaged it by mistake when removing it from the old pump to transfere to the new pump. So did i get a bad new level sensor or did i get the wrong one? The one i got is for 07Z and the pump is for the 07Z as well.
Any help would be much appreciated.
Old Aug 25, 2010 | 07:03 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by 99MALLETT396
Hello guys,
Not sure but why didn't you just get the pump and sensor for an 04Z? Maybe thats the problem?
Old Aug 25, 2010 | 05:50 PM
happa's Avatar
happa
You might need to get a tuner or the dealership to re-flash your pcm. It being from a 07 might have something to do with it not reading it properly. I have heard when people replace the sensor level they have to have the pcm re-flashed. Good luck!
Bryan
To Fuel Level Sensor
