David Pilgrim's 255 MPH Corvette sets new Speed Record at Bonneville
This is correct. There is also an interesting post around here about the factory body side moldings improving aerodynamics at speed as well.
Anyway ... Congratulations, David!
LO PHAT
Well done. I am surprised by the speed. The car is old but from
the factory a stock vette would be trapping in the low 170mph.
The record was lower than I would have expected considering
all of the speed parts etc out there to use. I would of thought
speeds would have been 275 plus. I wonder how many C-5's
are out in Utah trying to beat the speed record.?
GM itself states the coupe is more aerodynamic (.29 for the coupe and .31 for the FRC/Z06). Lingenfelter also chose a coupe for their top speed machine. Now how much difference this actually makes in reality I couldn't say.
David's wind tunnel testing has shown that of all the configurations he has tested, the bodywork with the lowest drag value was a result of the FRC body being optimized.
Which LPE car are you talking about? Another member referenced a C4 Lingenfelter/Callaway effort that went 254!!!
Ok, so where is this info? Saying something is "more aerodynamic" is ambiguous because it is usually a reference to L/D, which isn't the only target for top speed optimization. Or you could be referring to only downforce, or, only in terms of drag. What numbers are you quoting?
For the C5, we tested two different models. The first was a standard-edition Vette owned by Mark Connolly. The second was a Z06 owned by Tommy Megremis. Surprisingly, the baseline Corvette produced better aero numbers both in terms of drag and lift. Because it has a greater frontal area, the C5 Z06 actually has slightly more drag than a C4 Corvette. Much of this apparently comes from the Z06's redesigned nose. It contributed to more aero lift on the front end versus the standard model, while the Z06 had considerably less lift at the rear end.
All the C5 articles I read over the years have stated the coupe is more aerodynamic. Some from various GM engineers. Some of the Vette sites may still have these up. I wish I could give you some links, but it's been long enough I frankly don't remember. The FRC was developed as a lower cost option originally. The FRC was rated for less top speed from the factory (same gearing, etc). The C5R factory race cars choose the coupe shell, again for aerodynamics. Maybe someone at Katech or Pratt and Miller would share some numbers. Frankly I've read it so many times over the years, I'm surprised it's being discussed.
Again, you have to look at specific purposes of vehicle builds. Downforce is must less of a concern for a top speed car. PME choosing the coupe for basis of their bodies does not translate into why a top speed car would chose a body.
The article quoted that the Z06 actually had better "aero" on the rear axle, and worse front lift. Now consider that David is not running at stock ride heights/pitch values, and results will change. It is entirely conceivable, that due to the better rear values, and differences in set up, plus the removal of factory mirrors, that David could optimize the FRC body in lieu of the coupe.
Again, a lot of people bring up this one article. But you have to consider different goals (judging in terms of what is "better"), as well as differences in baselines that may result in values from David's wind tunnel tests, not correlating with a single magazines tests. We are not lying to anyone. As David has the fastest top speed Corvette, I would say he did a bit of homework first to make sure he chose wisely.
PME numbers would have nothing relating to OEM bodywork.
