Seized Spring Adjuster Bolts
Old Aug 26, 2010 | 02:54 PM
RX-Ben's Avatar
RX-Ben
Default Seized Spring Adjuster Bolts
ignore, found a different local shop that was able to get them out (destroying the adjusters).
Old Aug 26, 2010 | 04:03 PM
MagRedConv's Avatar
MagRedConv
I went through the same deal, soaked it (drivers side) in PB Blaster, WD 40, no help - wound up shearing off the head. At that point I said screw it and installed C5 Z06 springs.
Old Aug 26, 2010 | 04:04 PM
dougbfresh's Avatar
dougbfresh
Originally Posted by RX-Ben
The spring (front) is off the car, but the adjuster bolts still won't budge. I took it to my local garage, they had no luck either.
Anyone have any suggestions?
Leave it alone.
Old Aug 26, 2010 | 04:08 PM
RX-Ben's Avatar
RX-Ben
Unfortunately I need to adjust them for NASA TTB class time trials - I need to use stock springs to stay in TTB.
Old Aug 26, 2010 | 05:47 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Are you taking the load off the spring? I would recommend doing that if you haven't already. Take place enough pressure on the spring to separate the base pad from the control arm. PB blaster, a careful application of some heat possibly. After that, I might be yanking the spring off and double nutting it or using a quality stud puller to get some real leverage on it.
Old Aug 26, 2010 | 06:05 PM
RX-Ben's Avatar
RX-Ben
The spring is off the car.
I soaked it in PB for 24hrs and nailed it with an impact, nothing. I used a breaker bar on the other adjuster and rounded the head.
Anyone have a base model front spring (w/o seized adjusters) that they want to get rid of?
Old Aug 26, 2010 | 06:06 PM
Dope's Avatar
Dope
Resident moron
Soak it in PB blaster. Repeat every few hours.
Try heat on the bolt (like a torch).
Dope
Old Aug 26, 2010 | 06:08 PM
RX-Ben's Avatar
RX-Ben
Can heat really be used, given that the spring is fiberglass?
To Seized Spring Adjuster Bolts
