boost a pump install questions
Old Aug 26, 2010 | 11:08 PM
spoolin7's Avatar
spoolin7
Default boost a pump install questions
first off, is the racetronix wiring harness a must? i know it would be nice to have, but is it going to hurt to not have it?
now, i have the KB boost a pump installed in the car right now. I've got everything hooked up except for the actual power wires. I made the mistake of assuming the C5 was the same as the C6 and there was no handy connector in the left rear wheel well to tap into. the only thing i found that looked similar to the instructions is a connector near the passenger side tank, but it had like 7 or 8 wires, not 4 like the ones in the installation pictures on the C6. can anyone confirm where and which wires i'm supposed to cut and wire into?
