Headlight gears
Old Aug 27, 2010 | 07:45 AM
harleyvette's Avatar
harleyvette
Default Headlight gears
Which to buy? the brass gears with rubber bumper by Rodney Dickman or the brass, now (hard aluminum) gears without the rubber bumper by B.Frankers.
Old Aug 27, 2010 | 09:48 AM
cdkcorvette7's Avatar
cdkcorvette7
I have the Rodney Dickman gears... no problems after about 40K miles on them...
Old Aug 27, 2010 | 11:04 AM
hb32's Avatar
hb32
My passenger side started grinding for several seconds after closing last night. 2002 with 10,000 miles and very little use on the lights. What ever possesed GM to use plastic gears in a mechanical part that is used a lot?? I am also doing the research on which ones to use and both seem to be a little spendy...Corvette tax??
Old Aug 27, 2010 | 11:27 AM
KorbenDallas's Avatar
KorbenDallas
Doubtful about the Corvette tax as these gears are used in TransAms as well. These gears are well built and worth the $.
To the OP, I went with the brass since it was the only option available at the time. I haven't used them that much but they work like a champ when I have.
Old Aug 27, 2010 | 11:47 AM
leeinmemphis's Avatar
leeinmemphis
Question for those that have installed them......do you have to remove the assembly from the car to change the gear or can you just open the housing with it still in the car? I have a set coming this week because I have a gear grinding as well. Thanks.
Old Aug 27, 2010 | 12:10 PM
phil conrad's Avatar
phil conrad
1st Gear
You have to take the motor out of the car.
Old Aug 27, 2010 | 03:26 PM
hb32's Avatar
hb32
Thanks for the info and I was not aware of that.
Old Aug 27, 2010 | 07:30 PM
MG RED 99's Avatar
MG RED 99
I've had Rodneys for years now, no problems. If you buy the plastic ones you'll be replacing them again though.
To Headlight gears
