quick question inside about tire size
Old Aug 27, 2010 | 10:01 AM
everydaydriverz's Avatar
everydaydriverz
Default quick question inside about tire size
hello
i have a set of oem c5 z06 wheels will a 275 35 18 fit on them? thanks anyone have a pic if so please post in here
Old Aug 27, 2010 | 10:32 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
They will fit on the wheel, the range specified for that tire is a 9"-11" wheel. They probably won't look good (stretched) but they will fit.
Your real problem is that is a pretty short tire. The overall diameter is only 25.5 inches. If you have a stock tire size on the front, 245/45/17, they have an overall diameter of 25.7 inches. This means your front tires will be taller than the rears. This WILL create a problem for your traction control system. When the computer sees the rear wheels turning faster than the fronts it will activate traction control.
Old Aug 27, 2010 | 05:12 PM
everydaydriverz
great info thanks again
To quick question inside about tire size
