HUD Projector Replacment Help?
Old Aug 29, 2010 | 04:13 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default HUD Projector Replacment Help?
I have to replace a heads up projector in a 2001 convertible. Has anybody done one and whats involved.
Old Aug 29, 2010 | 06:35 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yes. It took me about 2.5 hours for my first time ever doing this. Essentially, you need to remove the center console, then the knee bolster and surround for the IP Cluster. From there, you'll need to remove the dash pad. I suggest you tie some strings to the sensors on top of it so you'll have them when you go to put the dash pad back in. Anyway, with the pad out, the HUD is easily accessible. Reverse everything to put it back together. Other than the sensors on top of the dash being a pain, its not a hard job. The most problems you might have will be around the dash pocket but maybe you'll have better luck than I did. Lost of little screws to remove and remember where they came from.
The HUD connects to the rear top of the IP Cluster, FYI via a small ribbon cable.
Old Aug 29, 2010 | 10:47 PM
FirethornC5's Avatar
FirethornC5
Look here...
http://forums.corvetteforum.com/c5-t...d-install.html
Old Aug 30, 2010 | 04:26 PM
Corvette ED
Thank You both for your help
Old Sep 3, 2010 | 12:01 PM
Corvette ED
I did the job start to finnish in less than 3 hours
Old Sep 3, 2010 | 04:50 PM
dgrant3830's Avatar
dgrant3830
Glad you got it done and thanks for updating us.
To HUD Projector Replacment Help?
