Gear/TC/PCM Install Question
Old Mar 28, 2002 | 04:17 PM
BLUBYU2002C5's Avatar
BLUBYU2002C5
Default Gear/TC/PCM Install Question
Have a question, I know you guys can help
Planning on doing a Gear/Tc Install soon, I was planning on getting
the PowerLoader II for the programming but at this rate ill be driving
the new C6 by that time, so I think im going to send the PCM out to
Ed Wright for the programming. Question is:
- Do I do I have the Install done, Drive the Car home 45-60 mins,
then take the Pcm Out and send it away??
or
- Send the PCM In,
Install it, then drive it 45-60 Mins to get the gear/tc Installed??
or
- Is it best to Send it out While the install is going on (1 day) and
leave it sit at the installers shop for 2-3 days (Don't really want to)
Will the Drive Screw anything up, or will it just not run right?? The drive
will be 95% Highway Driving
Mike
Old Mar 28, 2002 | 07:22 PM
Corvette4ever's Avatar
Corvette4ever
Default Re: Gear/TC/PCM Install Question (BLUBYU2002C5)
Ed Wright can send you a new PCM that you can install at the same time when you install the gears/converter. After that you can send him your original PCM as an exchange.
I don't know if it will screw anything, but I personally don't prefer to drive the car when I know that there is something wrong in it.
Good Luck
Old Mar 28, 2002 | 07:45 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Corvette4ever's suggestion of an advance exchange is an excellent one assuming Ed has an 02 available. It would certainly be nicer to pick the car up and have the job completely done. ;)
The biggest hang up to driving it with your current program will be that your shift points will be high. In the case of WOT shift points they may be over your rev limiter. Since you won't be hammering on it right away that shouldn't be much of an issue. The bigger the jump in gear, the bigger the issue. I drove my 3.73/SY3500 home w/o a PCM update, no issues.
Old Mar 29, 2002 | 10:13 AM
BLUBYU2002C5
Default Re: Gear/TC/PCM Install Question (ToplessTexan)
Thanks uys for the help will have to check into it with Ed Wright...
To Gear/TC/PCM Install Question
