Oil pressure switch
Old Aug 30, 2010 | 07:47 AM
nyliac's Avatar
nyliac
6th Gear
Default Oil pressure switch
Just bought my 2004 convert, and have not yet purchased the repair manual. Need to replace the oil pressure switch, however, can't locate it. Please help. Thanks
Old Aug 30, 2010 | 07:53 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Back of the intake near the firewall...
this link should help http://pages.infinit.net/vette747/IntakeManifold
its not the thread I was looking for but it shows you the sending unit
Old Aug 30, 2010 | 08:17 AM
nyliac's Avatar
nyliac
6th Gear
Bigger job than I thought, having to remove the intake to get to it! Thanks for the removal instructions, I'm guessing a new manifold gasket will be needed.
Old Aug 30, 2010 | 09:34 AM
sindekhan's Avatar
sindekhan
Default also need....
also need to replace that sensor, post how it goes if you don't mind and if it fixes it, my guage is pegged at 80 since i got it, read it's a common issue
Old Aug 30, 2010 | 09:35 AM
dougbfresh's Avatar
dougbfresh
Consider a relocation kit so you can move the sensor to a place more easily services.
Old Aug 30, 2010 | 09:43 AM
lucky131969's Avatar
lucky131969
You don't have to wait, do a search, and read for hours.
Old Aug 30, 2010 | 03:30 PM
Jeffwilson34's Avatar
Jeffwilson34
You may want to check under your wiper cowl and see if it has been changed before via the cutting method.
But when you change it do yourself a favor and seal it with heat shrink and silicone.
because
I think I figured what is causing some of the units to fail.
Moisture.
When I changed mine I had the cowl off and it had been changed before by the cutting method.
I left to cowl at the shop to paint and it rained and my new sender went crazy.
Advance swapped it out and it was fine but I could not help but spray some water down on it and bam it jumps up and pegs the needle.
I swapped it again but this time I used heat shrink tubing and silicone to seal the connections and soaked it with water and it worked fine.
That was almost a year ago and well over 30,000 miles. (my car has 229,500 on it now and is a daily driver.
The sensor on it now is one of the cheap pot metal looking ones from auto-zone.
I would suggest anyone that changes them to be sure and waterproof it.
Old Sep 26, 2010 | 01:53 AM
presto_vette's Avatar
presto_vette
i did step by step and accomplished the objective ..
Old Sep 26, 2010 | 09:31 AM
Etz's Avatar
Etz
Here is a poor video that I made. It is not only possible to do it with the manifold on, but easy. Hardest part is unlatching the plug.
http://www.youtube.com/watch?v=5PvlDLcyXX8
Old Sep 26, 2010 | 09:47 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
http://forums.corvetteforum.com/c5-t...um_id=1&arch=1
Old Sep 26, 2010 | 09:54 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
If I were you I would do a relocation of the sensor. Of all the fixes I have read about on the forum, the relocation seems to be the one that has no further problems. You will need to remove the intake but it's really not that hard.
Here's what I used to replace/relocate my sensor:
From Summit Racing
Autometer adapter ATM-2268
Earls fitting 982303ERL
Russel line RUS-658080
Russel fitting RUS-660410
From Lowes
Brass fitting 1/4 male to 1/8 female
Brass fitting 1/4 to 1/4 female
From Gene Culley gmpartshouse.com
Buick sensor 12584940
The finished product:
Old Sep 26, 2010 | 10:45 AM
tsts's Avatar
tsts
When I replaced my sender (cowl hole method), I used an older Buick brass sender because I could only find the pot metal ones at that time. Also had to use a thread adapter (brass) which raised it slightly but that did not cause any problems. My engine runs 48 lbs. pressure at idle and 65-70 at hwy. speed, been in for 1 1/2 years with no problems. The Buick sender was cheap most likely because of no "Corvette Tax". Didn't choose it because of price, chose it because it was brass.
Old Sep 26, 2010 | 12:03 PM
ZZ06's Avatar
ZZ06
for those who cant find brass here is a link where i purchased mine...pricey but worth it.
http://www.oreillyauto.com/site/c/de...3438&ppt=C0039
Old Sep 26, 2010 | 02:11 PM
Etz's Avatar
Etz
I used these two times on two different cars with no problems..
Old Sep 26, 2010 | 04:44 PM
nyliac's Avatar
nyliac
6th Gear
Looks easy enough! How did you get the plug back on the sensor?
Thanks,
jim
Old Sep 26, 2010 | 07:45 PM
Etz's Avatar
Etz
Thanks,
jim
I was able to get on using my fingers. You can use a pair of long needle nose pliers if you need to. The hardest part is getting the plug off, depending where the clip is.
To Oil pressure switch
