Help! Rattling Noise Over Bumps!
Old Aug 30, 2010 | 01:54 PM
hamdog's Avatar
hamdog
Default Help! Rattling Noise Over Bumps!
I have a '98 coupe with Pfadt shocks and C5 Z06 sway bars. I'm hearing a lot of rattling (front of the car) as I drive over bumpy surfaces. I can feel it under my feet and in the steering wheel.
Here is what I've done so far with no success:
-Installed brand new metal end links
-Inspected the sway bars to make sure there is no contact with the subframe
-Checked all bolts on sway bars and shocks to insure a tight fit
None of this work has made any difference. Any other suggestions or help would be greatly appreciated.
Old Aug 30, 2010 | 04:08 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
See if you can duplicate the noise in you garage. Sometimes I've had to raise a car and hit the tires with a big rubber hammer.
