1st to 2nd spinning
Old Aug 30, 2010 | 06:47 PM
upser23's Avatar
upser23
Default 1st to 2nd spinning
well i noticed my clutch pedal was feeling a little different its engaging almost at the top and when im spinning in first gear then shift to second the clutch is slipping and it doesnt do anything, but when im just cruising and stomp on the gas its fine...i was told it might be my master cylinder..ive changed the fluid from the reservoir and used Valvoline dot 3 and 4...do you guys think ill need a new clutch the car has 45,000 miles and is stock..thanks
