Thermostat which temp?
Old Aug 30, 2010 | 08:07 PM
Dale002's Avatar
Dale002
Default Thermostat which temp?
What temp Thermostat are you guys using?
Old Aug 30, 2010 | 08:09 PM
lucky131969's Avatar
lucky131969
......and were off......
Old Aug 30, 2010 | 08:13 PM
rustyguns's Avatar
rustyguns
yeah talking aBOUT A BEAT TO DEATH TOPIC LOL
I USE AUTOZONE'S 160 THERMOSTAT
Old Aug 30, 2010 | 08:53 PM
Dale002's Avatar
Dale002
Ok, Great! no need to go any futher. 160 it is.
You know, I just had to ask.
Thanks.
Old Aug 30, 2010 | 10:00 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
hypertech 160 thermostat with the fans set to cut on sooner
Old Aug 30, 2010 | 10:25 PM
Dennis Wilson's Avatar
Dennis Wilson
Same here!
Old Aug 30, 2010 | 10:27 PM
98vettedave's Avatar
98vettedave
Ditto!
Old Aug 30, 2010 | 11:13 PM
Dale002's Avatar
Dale002
Ok, !60 seem to be the one.
How do I get the fan to come on sooner and at what temp?
I
Old Aug 30, 2010 | 11:42 PM
0331MARINE's Avatar
0331MARINE
I
Mail order tune, hand held tuner, or a real street/dyno tune. I dont know what my fans are set on. Its been awhile.
Old Aug 31, 2010 | 08:00 AM
runner140*'s Avatar
runner140*
Nobody asked, THAT, question that stir's it up everytime.....about running cooler...woops, just stirred the pot. Sorry....
Old Aug 31, 2010 | 08:26 AM
Dale002's Avatar
Dale002
Can I just use the stat without tuning the fan?
Old Aug 31, 2010 | 08:48 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Won't do much without adjusting the fans.
Old Aug 31, 2010 | 08:53 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Knowing what a perfectionist “Lucky131969” is I’m sure he meant to say “and were off”...
Old Aug 31, 2010 | 09:10 AM
lucky131969
How dare you.
Old Aug 31, 2010 | 09:15 AM
98vettedave
actually if your on a continuous drive the 160 degree thermostat will keep the coolant temperature below the normal (stock stat) operating temperature. However,around town driving will require the fans to be adjusted before a lower operating temperature will be realized.
Old Aug 31, 2010 | 09:55 AM
Quick Silver Z
How dare you.
Is that a question or a statement (., ?)?
Old Aug 31, 2010 | 10:00 AM
lucky131969
Perhaps this will help:
http://grammar.ccc.commnet.edu/grammar/marks/period.htm
To Thermostat which temp?
Old Aug 31, 2010 | 10:12 AM
Quick Silver Z
So it’s not a statement or a question, it's a command!
Old Aug 31, 2010 | 11:43 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
A thermostat, no matter what the opening setting is, only controls how cold the coolant gets down too, not how hot the coolant gets, once its open, other conditions take over.. like speed and ambient temps, and surface temps. etc. the car draws all of its air 6 inches off the surface.. The statement that a 160 stat will lower your coolant temp without adjusting the fans is incorrect. If you run a 160 stat year round , and its 20 F outside your car will run no colder than 160 but, because its running at that temp the oil temp will be way lower than that required to lubricate the engine properly especially the top end.. cold oil is much worse than hot oil. Once the engine is at operating temp the oil temp should be optimally at 200/220 F. Remember a 160 stat can still see 250 F coolant.. the only reason to put in a lower stat is to be able to lower your fan on temps.. and because they are electric driven.. they are designed to cycle on and off not run constantly.. They will fail prematurely if this is done, and your engine will never see 200K if you run constant oil temps below 200 F. Thats all folks
I run a 160 in the summer and a stock stat in the winter with appropriate fan settings.
Old Aug 31, 2010 | 11:46 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
How dare you.
Someone finally gotcha!
