getting alignment....prefered specs?
Old Sep 2, 2010 | 08:18 PM
87gtNOS's Avatar
87gtNOS
Default getting alignment....prefered specs?
Saturday morning....
Is there a prefered spec? I have found all the charts and whatnot that are posted, but haven't found anyone saying one spec is prefered, etc....
99 C5 lowered on stock bolts....camber is currently at zero degrees on the fronts.
Old Sep 2, 2010 | 08:44 PM
tommie's Avatar
tommie
i set mine up on stock c5 z06 specs...
Old Sep 2, 2010 | 08:47 PM
minitech's Avatar
minitech
Depends on what you want to do with it. For optimal handling have the shop put on factory specs throughout; then have them lower the car to one half inch lower than stock front and rear.
For your lowered car it might need to go up a bit.
Might not have the look you want and that is a different story. If the car is just for static parked looks just have it aligned standard and lower it til it looks good to you regardless.
Old Sep 5, 2010 | 11:13 PM
j84buick's Avatar
j84buick
I went with the Z06 specs after I lowered and went with wider wheels.
Old Sep 6, 2010 | 09:02 AM
87gtNOS's Avatar
87gtNOS
Thanks guys for the input...I went with 01 Z06 specs.
Car goes nice and straight now, and seems to corner smoother.
To getting alignment....prefered specs?
