I have a 2000 FRC and am thinking about installing a later model LS7 motor in it. Are there any threads on the forum where someone has already done this?
I don't want to reinvent the wheel if someone has already done it.
Thanks in advance for any help.
LS1 tech forum perhaps? I know lots of these swaps have been done, sometimes retaining the dry sump, sometimes not. Some use a different dry sump setup too, not trusting GM's unit.
It's a lot easier if you change it to a wet sump setup. If you do that, you'll need an electronic adapter to change the reluctor wheel signal to be compatible with your PCM. You'll need a couple harness extensions/adapters for the knock sensors, cam sensor, throttle body. You will have to extend the MAP wires. None of which is a big deal.
If you leave it dry sump, there are aftermarket systems that may be easier to fit than the stock LS7 system. You'll probably have to relocate the battery to the truck either way.
Another option for a 427 is to do what I did and Darton sleeve and LS2 block for a 4.125 bore with a 4.0 inch crank. You'll end up with a much stronger engine.
^^ Yep and then you have the L92 427 option as well to save some money. All of them will bolt right in, that is not a concern for you (OP). If you have an engine built you order the correct reluctor with the crank so you don't need the converter box.
Can anyone tell me a little more about the L92 option? This sounds like an interesting possibility, as the more I research the LS7 engine, it sounds like it may have some inherent weaknesses. The reason it initially sounded good was I wanted something that would be basically a stock GM crate type engine which I could cam up a little to get a little more power.
You may want to give SDPC a call and talk to them about options. They are great to deal with. I did my LS7 based 427 (with ported L92 heads) for less money installed than the GM LS7 costs just for the crate engine. This includes the nice touches that I chose such as the Katech valve covers.
I had ECS do an LS7 crate motor in my C5Z with a dry sump. They changed to the 24 tooth reluctor wheel, custom fitted an LS7 based Aviaid dry sump system and did a custom rear-mount battery box. LPE also makes some helpful conversion kits if you don't have a shop nearby to do the custom work. The LS7 setup in my car looks OEM.
Correct the sleeves leave a little to be desired but it should be ok for a n/a application. For the cost of the LS7 block you could get an LS2 re-sleeved and be ahead of the game.
The LS3 427 is a 4.070 bore x 4.100 stroke. As such it is not recommended for a power adder ( nitrous or boost). It is the least expensive of the 427's. You can run a set of L92/LS3 heads on it and make decent power for decent money. The short block is $5550, or $10,200 intake to oil pan for a very nice combination.
