A Tune on My C5
Old Sep 3, 2010 | 07:56 PM
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
Default A Tune on My C5
Okay do I need a tune on my '03 C5 vert? Is stock except for new corsa pace car cat backs and x-pipes. thinking about a Blackwing or K&N at some point. Is a street car like to cruise, and get on it at stop lights just to feel good!! What will I get from a tune?? I don't know what to ask for so am I in the group that doesn't need it? Thanks for whatever you can impart on this whole thing. Lastly how much would o ne expect to pay for a "tune"
Old Sep 3, 2010 | 08:08 PM
MagRedConv's Avatar
MagRedConv
$400 or so.
Old Sep 3, 2010 | 08:30 PM
tomringo's Avatar
tomringo
Nice but what do you get for 400? What can I expect once its done.
Old Sep 3, 2010 | 08:35 PM
rebelheart's Avatar
rebelheart
No real need for a tune as yet.
Old Sep 3, 2010 | 10:16 PM
kp1's Avatar
kp1
What you'll get from a tune is changing the Power Enrichment mode so it doesn't run pig rich at WOT. That'll wake it up a little. What you'll also get is a more aggressive spark advance at least in the higher RPM's at WOT or lower vacuum.
You don't need a tune at this point and you certainly don't need to spend the money for a dyno tune. If you are determined to get better throttle response and power as the car sits, there are some guys that have tuned a raft of stock LS1 engines and can fix you up for $150 or so.
Old Sep 4, 2010 | 10:47 PM
retired cop's Avatar
retired cop
If its an auto they can firm up the shifts and set it so it shifts at 6000 rpm. Also improve the kick down response and reset when the converter locks up if you like!!
Old Sep 4, 2010 | 10:48 PM
retired cop
Mine was a street tune it was 250.00
Old Sep 4, 2010 | 11:54 PM
T-TOP TOM's Avatar
T-TOP TOM
I just had my 01 auto tuned at Carlisle by ECS it had a bog when it shifted from 1st to 2nd after a transmission replacement. They got rid of the bog plus the cars runs much stronger now. They changed the fans to turn on earlier and change a lot of other things. I watch them while they tuned it. They took their time and the results are great. I believe they have a bench tune fee of less than $100 if you send your computer in and they will bench tune and return it the in the same day mail. If you would search for "bench tune" you will find many praises for their bench tunes. The car is stock excepdt Ti exhaust but runs like a different car after tune. Good Luck
Old Sep 5, 2010 | 07:59 AM
oakvillec5's Avatar
oakvillec5
interesting reading
Old Sep 5, 2010 | 09:20 AM
Dale002's Avatar
Dale002
Does a street tune change your gas mileage?
Old Sep 5, 2010 | 09:24 AM
Michael99Vette's Avatar
Michael99Vette
99 convertible. I had DTE install a 3.73 rear end and I installed a vararam with power duct. I then took my car and had it dyno tuned. Neither one of these improvements will show up as extra HP and TQ on a dyno so it's pretty much stock. After the tune it was... 305.32 RWHP and 304.97 RWTQ. That's a very good difference from approx. 276 RW HP and TQ. I could really tell the difference as soon as I pulled out of the parking lot. Since, I have added the Melrose header system (includes free flow cats), corsa touring exhaust, Katech ported TB and a ported, O/S MAF sensor. I need to get it back there and get another tune. My guess... I think about 350 RWHP and TQ. My point... a dyno tune is well worth the cost. This dyno tune cost me $500.00 (VetteSport out of Smyrna, TN.)
Old Sep 5, 2010 | 09:47 AM
Michael99Vette
99 Conv. I forgot... I put an LS6 intake on, also.
Old Sep 5, 2010 | 11:46 AM
MagRedConv's Avatar
MagRedConv
OP, that's the difference between a mail order tune and a dyno tune. Mail order, you get what's sent back, period. Dyno, it's tuned and tweaked right there with a dyno sheet to show the gains.
I have an A4 and was putting out pretty much the same rwhp as stated above (I had a K&N filer, Corsa cat back with X-pipe as the only "mods").
After the tune, which included four or five tweaks, I was at 313 rwhp.
I added the LT's a couple of months later, re-tuned and dynoed and am at 335 rwhp, 345 ft. lbs.
Note that I'm not putting down mail order tuning; I'm just one of those people that want's everything exactly right and a dyno sheet to prove the numbers.
Old Sep 5, 2010 | 12:06 PM
TurboBerserker's Avatar
TurboBerserker
A mail order tune is a generalized tune (just like the stock tune, so not bashing here) that the MO company can send out with relatively safety. They will tweak it a bit towards your particular mods, but without data from your car running in your ambient environment, its not going to be a maximal gain tune.
A dyno tune, on the other hand, is built from running your car and extracting data both from a running scan of your car, and the dyno. The tune is adjusted to make more gains and to suit the exact nature and running condition (mods, temps, etc.) of your car. This will produce maximal gains with a good tuner.
Each has its own niche. Each serves a purpose.
Do you need a tune with your mods? Probably not. Should you consider a dyno tune as a mod? If you are interested in min/maxing your performance, then yes.
To A Tune on My C5
