HVAC Motor quit
Old Sep 3, 2010 | 11:32 PM
mscan's Avatar
mscan
Default HVAC Motor quit
The HVAC fan in my '04 quit working. Checked the maxi fuse under passenger side kick panel, it was fine. The panel shows the fan speeds going up and down but I've got nothing. It never made a noise just worked and the next time I got in the car, nothing...any suggestions?
Old Sep 3, 2010 | 11:41 PM
lucky131969's Avatar
lucky131969
You can test the blower motor itself to see if it works. If it does, then it's most likely the blower motor control processor. But I suggest using the schematic and a meter to check everything out.
Old Sep 3, 2010 | 11:50 PM
mscan's Avatar
mscan
Never mind...figured out how to use search and I see this has been addresed
To HVAC Motor quit
