No Fire
Old Sep 6, 2010 | 12:17 AM
Derald's Avatar
Derald
Default No Fire
My 2000 got hot about 222 degrees and I blew a hole in the surge tank about the size of a quarter on the engine side. After it coooled down I started it up and drove it on a trailer. Got home started it and drove it off the trailer and then home 1 block. I installed a new surge tank, after about a week of setting and now it won't fire. It was running great then I took it to a dealer and had the radiator flushed. I was running the Dex Cool and when they changed it they put in the green. All this happened about 80 miles from the change. Anybody had this problem???? Thanks,Derald
Old Sep 6, 2010 | 12:24 AM
lucky131969's Avatar
lucky131969
A dealership put in green coolant?...interesting. I assume when you say it "won't fire", you mean it cranks, but will not start. If so, do you have fuel pressure? Fuel getting in the cylinders? Do you have spark?
Post your codes.
http://www.c5forum.com/ayc/dtcdic.php
Old Sep 6, 2010 | 09:17 AM
Derald's Avatar
Derald
The car turns over normal. How do check to see if it's gettting fuel ?????? Thanks, Derald
Old Sep 6, 2010 | 09:54 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
222 degrees is not hot, it's within the normal operating range for the engine. I doubt that running the green coolant vs. the DEXCOOL is the source of your no-start problem.
I'm not trying to be insulting but you appear to have limited experience with the inner workings of the car, I recommend you get a service manual if you do not already have one.
As for the no start issue, I would start by pulling any codes and checking all of the fuses in the fuse block located adjacent to the battery.
Old Sep 6, 2010 | 11:59 AM
hotwheels57's Avatar
hotwheels57
The dual electric fans haven't even kicked on at 222 degrees by factory design. That's not hot for an LSx motor.
Old Sep 6, 2010 | 04:38 PM
Derald's Avatar
Derald
I realize changing the orange anti-freeze to green is not my starting problem. The hot coolant blowing out of the surge tank engine side must have penetrated something that's causing my problems. Maybe PCM I don't know. Derald
Old Sep 6, 2010 | 05:06 PM
lucky131969
Day two. You need to attach a gauge to the fuel rail to check pressure. Have you pulled a plug to see if fuel is getting in the cylinders. Do you have spark? You have been asked twice to pull codes, and still have posted nothing. If you want assistance, you will have to provide some info.
Old Sep 7, 2010 | 07:07 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'm wondering if he's blown the surge tank, where is that pressure coming from? It should handle the normal pressures. Might want to pull the plugs and look for coolant on them and hope none is found. Codes should tell the tale.
Old Sep 7, 2010 | 07:15 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Old Sep 7, 2010 | 06:30 PM
Derald's Avatar
Derald
I narrowed down my problem to the fuel pump relay. I switched The AC relay and boom it fired right up. WHEEEEUUUU!!!! I was not getting any codes from the diagnostics. Another relay for the AC and I'll be good to go. Hey I really appreciate you guys for all the come backs, Thanks one hellavala for the help, Derald
To No Fire
