Headlights Occasionally dont come up
Old Sep 6, 2010 | 02:49 PM
ianlift's Avatar
ianlift
Default Headlights Occasionally dont come up
Once in a while, the headlights dont come up when starting the car in the dark. If i pull the key and wait 30 seconds for so it usually corrects itself. This seems to happen once in a while if i have the key in acc. positon for a bit and then start the car.
Any suggestions? I am thinking of going aftermarket lights because even though the lights aren't up...the ARE on..
Old Sep 7, 2010 | 07:20 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The normal cause we hear about headlamp issues is the headlamp or multifunction switch. Its got a fairly high failure rate. There are only two other components, the BCM and the headlamp control module. The headlamp control module basically opens and closes the doors.
