Removing bulb...
Old Mar 29, 2002 | 01:31 PM
B. Stewart's Avatar
B. Stewart
Default Removing bulb...
I know that this really sounds stupid but I can't get the tail light bulb out of the socket! I pushed 2 little pins on the side of the socket and the bulb + what looks like part of the socket (it's a beige color) came out and then I can't get the bulb out of it! Am I doing something wrong? Any tips would be appreciated. :mad
Old Mar 29, 2002 | 03:04 PM
THRAP 42's Avatar
THRAP 42
Default Re: Removing bulb... (B. Stewart)
Manual says:
Tail Lamp Replacement
Removal Procedure
Remove the screws retaining the tail lamp assembly to the rear fascia.
Remove the tail lamp from the fascia to gain access to the tail lamp socket.
Remove the socket from the lamp assembly.
Remove the bulb from the socket, if replacing the bulb.
Remove the tail lamp from the vehicle.
Don't know what else there is to do. This came from; http://si2kam20:am201100@service.gm....model=Corvette , it has some diagrams but not in great detail.
Good luck,
later,
Old Mar 29, 2002 | 03:54 PM
B. Stewart's Avatar
B. Stewart
Default Re: Removing bulb... (THRAP 42)
Thanks for the reply. That is what the manuals say but the bulb won't come out! Maybe you have to use extreme force! I called Exit 28, where I purchased them from, and they said that they should just twist out...no such luck. :confused:
Old Mar 29, 2002 | 05:46 PM
jimhild's Avatar
jimhild
Did you try pushing down on the bulb before trying to turn it? I think most of these sockets have a detent that has to be released first. I didn't have any issues with replacing my taillamp bulbs.
Good Luck!
Old Mar 30, 2002 | 12:10 AM
C5stein's Avatar
0C5stein
Former Vendor
Default Re: Removing bulb... (jimhild)
He is right, you gotta push down before you turn, but sometimes they get really stuck and you need to use some force. I would make sure to put on some gloves incase you get a bit over zelouse and break the bulb glass. It cuts the poopie out of your finger tips :cry
To Removing bulb...
