From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
camber question...
Just got new tires and wheels put on today. When I look at the passenger side rear wheel (305/30x19) the tire looks nice and flush with the body line while looking from the rear of the car. But on the driver side I could swear the tire is about a 1/4" outside the body line. The last alignment I got I asked for and got a Z06 alignment. Would that explain different camber from one side of the car to the other?
No... There are plus and minus tolerances but NOTHING that would be visually different even if each side were set at an extreme opposite of the tolerance range.
Looks can be deceiving, the camber adjutment should be equal on both sides. With the car parked on a flat level surface you can use a large carpenter's square placed against the floor and mid-point of the lower edge of the tire and measure the distances from the vertical edge of the square to the wheel lip and the high and low points to determine the camber angle.
On an 18" wheel approximately .300" equals to 1 degree of camber. If the distance is greater on top, the camber setting is considered to be negative. You can use this information to either adjust it yourself or take it back to the shop and ask why it's off.
What I would do is take the car back to whoever did the alignment and show them the difference in the two front wheels, and ask them what the problem is.
