Help DTC's after LS2 403 install.
Old Sep 11, 2010 | 02:21 AM
TimbrSS's Avatar
TimbrSS
Default Help DTC's after LS2 403 install.
Just installed a 403, engine runs great, but having a couple problems with DTC's. I hope the problems are obvious to someone.
DTC P0343 Cam postion ckt Hi volt. Using a caspers extension harness. I swapped the outside wires on the harness, and got DTC P0343 Cam position ckt low volt... DTC's come back after I clear them. Anything to check?
TCS:
DTC C1248 DRP disabled
C1234
C1235
Rear wheelspeed sensors. reseated EBCM connector, codes come back when I try to clear them.
Hopefully I just forgot to ground something.
02 z06
