Fob issues help
Old Sep 11, 2010 | 04:23 PM
BOUT X's Avatar
BOUT X
Corvette Cowboy
Default Fob issues help
Hey guys just got my car back after a 3 month re-build and when I re-program my FOB it works great for 1 day Then it needs to be re-done I have no codes at all the FOB's worked perfect before. One of them is only 6 months old the other is original Factory FOB it is my spare any help would be great TIA.
Dale
Old Sep 11, 2010 | 05:54 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Did you do the quick resynch procedure of the full program procedure?
The full procedure:
Programming Transmitters
1. Turn the ignition to ON.
2. Turn the radio to OFF.
3. Press the RESET button in order to clear any IPC warning messages.
4. Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
5. Press and hold the RESET button for 3 seconds.
6. Press the OPTIONS button until FOB TRAINING message is displayed.
7. Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1ST FOB will be displayed.
8. Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
Old Sep 11, 2010 | 06:14 PM
BOUT X's Avatar
BOUT X
Corvette Cowboy
The full procedure:
Mark I will try this and see if it works thanks for the procedure
Dale
Old Sep 12, 2010 | 09:39 PM
Coal is King's Avatar
Coal is King
My FOB was sporadic at best and then quit working all together. I found a thread on this site....I think, about the soldered connection at the battery boot to the circuit board. I checked mine out and sure enough there was a hairline crack in it breaking the connection. So I resoldered and it has worked perfectly since.
Old Sep 12, 2010 | 10:31 PM
BOUT X's Avatar
BOUT X
Corvette Cowboy
well I tried to do the programming this way and it works for a minute then no go then stops working WTF I cant figure this out HELP
Old Sep 12, 2010 | 10:38 PM
Coal is King
Did you open it and look at the battery connection. I tried the programming procedure as well and was having the same result. Turned out to be the soldered connection at the battery.
To Fob issues help
