Climate control passenger side
Old Sep 11, 2010 | 07:33 PM
mcviooue's Avatar
mcviooue
mcviooue
Default Climate control passenger side
Since two years I have my 2000 conv. corvette. I have the dual zone Climate control. The button on the passenger side never worked. But it was not a big problem; I used the left button to control the air conditioner on both side and everything worked fine. But today, I had a problem. The air on the driver side was working well, it was cold as I need it but on the passenger side, the air was always the same, hot. No way could I change the air control on that side, except putting the air control off. Can somebody help me with that problem ?
Mc
Old Sep 11, 2010 | 08:59 PM
dmarkshark's Avatar
dmarkshark
First, check your DIC for any codes. If its blowing cold on the dirvers side and not the passanger it is probably you passenger side actuator, but first check for any codes. If you do not know how to do this do a search, its all over the place.
Old Sep 12, 2010 | 07:44 PM
mcviooue's Avatar
mcviooue
mcviooue
Default Actuator
Hi! I did check my codes and there's none. The actuator, is it a part in the AC module?
Thanks Mc
To Climate control passenger side
