install new fuel pump > how much work
Old Sep 13, 2010 | 06:35 PM
baezi z06's Avatar
baezi z06
Default install new fuel pump > how much work
hi
How much work is it to install new ractronix fuel pump in tank, replace the old one, and install the new racetronix wire harness...
in 2003+ fuel system version C5
is it rear cradle/suspension and tranny out or?
thanks
Baezi
Old Sep 14, 2010 | 07:15 AM
baezi z06's Avatar
baezi z06
Originally Posted by baezi z06
hi
thanks
Baezi
has no one upgraded their fuel pump in 2003-2004 Vettes
Baezi
Old Sep 14, 2010 | 03:27 PM
baezi z06's Avatar
baezi z06
Old Sep 14, 2010 | 04:06 PM
dougbfresh's Avatar
dougbfresh
I thought the later model pumps came out pretty easy, it should be in the service manual!!
Old Sep 14, 2010 | 05:17 PM
Russ K's Avatar
Russ K
If your fuel pump is on top of the left tank, then you have the FFS fuel system. The driveline has to be removed to be able to remove the fuel tank. What is your fuel pressure dropping to at WOT at redline? Maybe a boost a pump will increase the output enough.
Russ Kemp
This article says you don't have to remove the driveline; http://www.corvetteactioncenter.com/...el+Tank+System
Old Sep 15, 2010 | 04:02 AM
baezi z06's Avatar
baezi z06
Russ Kemp
thanks
i was hoping to see pics from somebody of step by step installing a fuel pump in 2003-2004 Vette
baezi
Old Sep 15, 2010 | 07:06 AM
dougbfresh's Avatar
dougbfresh
thanks
baezi
Buy the service manual.
Old Dec 19, 2010 | 06:35 AM
baezi z06's Avatar
baezi z06
Just finished my Racetronix pump harness install.
1.The Drive train went down
2. left tank needs to go down: needs to disconnect lines between the tanks (it´s disconnected on the left tank)
3. Disconnect hose on top of the left tank (the refill hose) and disconnect air hose there too
4. Disconnect fuel line and a plug
the tank is loose
5. Then it´s opening the tank up
6. taking the pump and acessories up out of the tank is very tight and stiff, but whith pation it´s will come up
7. then swapping pumps, plug n´d play, and clean it all well
8. Install again
it´s not a hard work, but offcousre this all takes time, if it´s the first time.
Baezi
To install new fuel pump > how much work
