camshaft sensor code
Old Sep 19, 2010 | 08:11 PM
sikboy's Avatar
sikboy
1st Gear
Default camshaft sensor code
just had a new motor put in 2002z,had it on dyno and tuned at 500 miles,did 437hp,has heads,cam,air,exhaust, w.e.,at around 800 miles car started to backfire a little bit which i guess is normal.then starting car up it stalls out now on occasion,set check engine light and set camshaft sensor code....have been through hell with this car!!!!please help me out and give me some feedback here PLEASE!!!
Old Sep 19, 2010 | 09:34 PM
lucky131969's Avatar
lucky131969
Really hopes if you explain what type of motor, and which code...as there are three for the camshaft sensor. . Assuming you have an LS1/6, and the camshaft sensor is still at the rear of the motor, all you can do is check out the wiring with a meter...inspect the sensor itself, etc. Unfortunately, you may be the victim of the cam bolts being loose, or cam plate allowing movement.
