Overheating tried everything need help
Old Sep 20, 2010 | 10:18 AM
gocanes452's Avatar
gocanes452
5th Gear
Default Overheating tried everything need help
I have changed the radiator , water pump ,thermostat ,hoses are not collapsing changed engine temp sensor burped the system.Fans are coming on , I have also ran the fans on full time. Car will not over heat on idle or low speed driving. The car overheats on highway driving or if i hold down the gas at 3000 rpm when parked. Blocked catalityc??? I have no coolant loss or white smoke or mixing happening. Any ideas???
Old Sep 20, 2010 | 01:49 PM
BigGun's Avatar
BigGun
[QUOTE=gocanes452;1575378948] I have changed the radiator , water pump ,thermostat ,hoses are not collapsing changed engine temp sensor burped the system.Fans are coming on , I have also ran the fans on full time. Car will not over heat on idle or low speed driving. The car overheats on highway driving or if i hold down the gas at 3000 rpm when parked. Blocked catalityc??? I have no coolant loss or white smoke or mixing happening. Any ideas???[/QUO
How hot is it getting? Do you have bubbles forming in the reservoir tank when running at 3000. Possible that exhaust gas is entering the system. If you suspect that may be happening there is a test kit you can buy that will test for this.
Old Sep 20, 2010 | 02:14 PM
gocanes452's Avatar
gocanes452
5th Gear
I'm going to try and find the test at my local auto parts. I am really hoping it's not my heads!
Old Sep 20, 2010 | 02:19 PM
gocanes452's Avatar
gocanes452
5th Gear
BigGun my car is located at the moment in my parents house in Greensboro NC, any vette shops in NC ?
Old Sep 20, 2010 | 02:41 PM
BigGun's Avatar
BigGun
The only one I have worked with is Carolina Auto Masters in Durham. They know vettes inside and out. I think there are several near the coast. You might ask in the regional section and get some more suggestions.
Old Sep 20, 2010 | 04:05 PM
Oldvetter's Avatar
Oldvetter
Are you sure that you car is over heating ? Could the temperature sensor be bad?
Also, have you looked up at radiator front, is there debris on the radiator? If not, have you blown air or water from the engine side to clean it out (you can remove the top radiator cover to see if material is between air conditioner coil and radiator).
Old Sep 21, 2010 | 01:20 AM
gocanes452's Avatar
gocanes452
5th Gear
The radiator is brand new so it is clean. I also cleaned the condenser. I changed the temp sensor as well. I did notice the pcm to be hot to the touch the other day. But i had no codes on scan tool!
Old Sep 21, 2010 | 05:15 AM
cdkcorvette7's Avatar
cdkcorvette7
What he said... Check for bubbles in the tank while the car is overheating. You've certainly thrown a lot of parts at this thing to still be having problems...
Old Sep 21, 2010 | 08:55 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I think what he meant to ask you was not about the radiator being clean, rather the condensor. The air coming in goes through it first, before getting to the radiator and its what catches the bugs, rocks, bags and etc... It really does need to be washed out. Usually what we hear is the temps rising at idle and going down while driving. The fans shut off at something like 35 MPH or should....otherwise they will interfere with the air-flow coming in. Maybe they aren't shutting off? No clue how to test unless you wire up a light into the cockpit. So you have no leaks, yet overheat. Usually an issue with air trapped in there and there is a procedure for burping it although I don't know what it is. If a head gasket is blown, you'll most likely see bubbles in the coolant pressure tank and/or hissing out the radiator cap or tank.
Old Sep 21, 2010 | 10:12 AM
MrHiPerf's Avatar
MrHiPerf
Radiator (reservoir) cap? If you have a leak there it would cause an overheat situation and you would not necessarily see it. I didn't see you mention it.
And wouldn't a head gasket make your oil look milky?
Old Sep 21, 2010 | 01:13 PM
dgrant3830's Avatar
dgrant3830
It would not show in the oil if it blew between the cylinder and a water jacket. If it blows into an oil passage and connects the water jacket into the oil passage, then yes, it would turn the oil milky.
Old Sep 21, 2010 | 10:21 PM
01vetter's Avatar
01vetter
Perhaps your coolant is air bound. Did you purge the air properly?
Old Sep 22, 2010 | 08:00 AM
runner140*'s Avatar
runner140*
If you "burped" the hell out of it.....are you absolutely sure that the new t-stat is good. Had a similar problem with a tstat....two new ones were defective. Three was a charm. Test them first in a pan of boiling water and see...1. if they open and 2. at what temp.
Old Sep 22, 2010 | 09:59 PM
americanretrodave's Avatar
americanretrodave
I'm not sure if this would happen on a Vette but I have had it happen on two other cars: I've had an air pocket displace the coolant and had to incline the entire car to get it out. If you have this problem, find a steep hill to drive up, check you fluid level afterwards.
Old Oct 5, 2010 | 09:06 PM
gocanes452's Avatar
gocanes452
5th Gear
after many times burping the system the car will not overheat. Thanks so much for your help guys!
To Overheating tried everything need help
