Where to get a Harmonic Balancer Installer tool?
Old Mar 30, 2002 | 11:41 PM
C5Noir's Avatar
C5Noir
Default Where to get a Harmonic Balancer Installer tool?
Instead of paying almost $100 for KentMoore tools for our cars can't I just get a Harmonic Balancer Installer tool somewhere else? Thanks.
Old Mar 31, 2002 | 01:16 AM
Gary2KC5's Avatar
Gary2KC5
Default Re: Where to get a Harmonic Balancer Installer tool? (C5Noir)
totally confused!!
When I put on my under-drive pulley (removing the "harmonic balancer") I replaced the used aluminum bolt with a new one and torque'd it to the correct spec and then tighten to the correct degree.
What "tool" is required? (besides BA biceps to crank the bolt to 140 degrees)
Old Mar 31, 2002 | 01:19 AM
C5Noir's Avatar
C5Noir
Default Re: Where to get a Harmonic Balancer Installer tool? (Gary2KC5)
You use this initially to seat the harmonic balancer or ASP pulley on to the crank. Then you reuse the old bolt, torque it to 240 lb/ft, remove it, install new bolt, torque to 37 lb/ft then turn it 140 degrees clockwise. I assume it's not all that necessary, the installer.
Old Mar 31, 2002 | 01:31 AM
66ImpalaLT1's Avatar
66ImpalaLT1
The installer is necessary with the stock pulley on F-Body LS1's. I dont know for sure if its necessary with the stock pulley on C5's since they are different.
I've been told by many different sources that it is not necessary with the ASP pulley and you can simply pull it on with the bolt.
Eric
Old Mar 31, 2002 | 01:33 AM
C5Noir's Avatar
C5Noir
Default Re: Where to get a Harmonic Balancer Installer tool? (66ImpalaLT1)
The GM manual for the C5 claims it needs it but I agree the ASP should go on w/out a hitch. Eric, are you about ready for the T1 install?
Old Mar 31, 2002 | 01:56 AM
intel55's Avatar
intel55
no special tool that I used for installing. Uninstalling used the "prong." Just do not use the old bolt :D
:cheers:
Old Mar 31, 2002 | 01:57 AM
66ImpalaLT1
I didnt get a chance to work on it today, but I did get everything cleaned up in the garage so I'm all ready. I'm going to start tomorrow. I've done 1 day marathon cam swaps before, I'm planning on taking this one slow and take lots of pictures.
I ordered the Kent Moore flywheel holding tool that bolts in place of the starter, but I hope I wont need it. If I absolutely need it then I'll be delayed until wednesday or thursday when it comes in.
Eric
Old Mar 31, 2002 | 02:00 AM
C5Noir's Avatar
C5Noir
How much was that tool? I read you can just unbolt the starter and stick a screwdriver in there. Hey, if we do need it, could I borrow it from you? I'd send it back and pay for shipping, etc. ;)
Old Mar 31, 2002 | 02:12 AM
66ImpalaLT1
It was $55, I can loan it to you when I'm done. I wonder how much room you have around the header by the starter.
When do you think you'll be installing your heads/cam?
Eric
Old Mar 31, 2002 | 09:38 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Where to get a Harmonic Balancer Installer tool? (intel55)
:cheers:
ditto...just to clarify the "don't use old bolt" statement. You do use the old bolt, just as C5Noir explained above, to seat the new pulley in.
then torque the new bolt down and stretch it in place.
[Modified by Gary2KC5, 7:38 PM 3/31/2002]
Old Apr 1, 2002 | 10:41 AM
Fast one's Avatar
Fast one
A piece of threaded rod and nuts places the wear on the rod and not the crank. Use as high quality rod and nuts as you can find; tighten the nuts at one end and screw the assembly into the crank. Remove the nuts and place an old pully or other filler on the rod then a washer and one nut. Grease the rod threads and tighten the nut then remove the assembly using two nuts.
Old Apr 1, 2002 | 04:30 PM
MDT's Avatar
MDT
Default Re: Where to get a Harmonic Balancer Installer tool? (Fast one)
Fast one,
That's the way I have always "pulled" balancers onto the crank snout, for exactly the reason that you outlined.
Good luck.
Mark
Old Apr 1, 2002 | 06:06 PM
66ImpalaLT1
Default Re: Where to get a Harmonic Balancer Installer tool? (MDT)
Ok, you guys convinced me. I called the local fastenal and ordered up 1 meter of 16mm class 8.8 rod.
Now that I've started working on my cam swap I've convinced myself to go almost $500 over budget. I hate it when i do that :(
Hopefully I can get everything by the end of the week.
Eric
Old Apr 1, 2002 | 06:38 PM
C5Noir's Avatar
C5Noir
Ok, I'm thoroughly confused now. What does this "rod/nut assembly" look like? Thanks.
Old Apr 2, 2002 | 09:57 AM
Fast one's Avatar
Fast one
It looks like; as long as you can fit piece of threaded rod that is threaded into the crankshaft. The balancer is started on the shaft then some kind of filler to push on the center of the balancer not the edges such as a large pulley, socket or thick piece of steel; then washers and finally a nut that threads onto the threaded rod. As the nut is tightened on the threaded rod, the balancer will be pushed onto the crank shaft then the threaded rod is unscrewed and then the balancer retaining bolt is screwed into the shaft. The same parts remove the balancer with the addition of a thick piece of bar steel that has additional holes that match the tapped pulling holes in the dampener; the nut on the threaded rod goes behind the steel bar (which is screwed into the dampener by two or three long bolts) and when turned pulls the dampener off the crankshaft.
Old Apr 8, 2002 | 11:40 PM
C5Noir's Avatar
C5Noir
Is this all really necessary? The Helm's manual says to use the old bolt to seat the pulley as well as the ASP instructions :confused:
To Where to get a Harmonic Balancer Installer tool?
