97 vette column lock issue
Old Sep 22, 2010 | 12:46 PM
dkrose54's Avatar
dkrose54
Default 97 vette column lock issue
i bought a 97 one owner and it ran fine for 100 miles, left it set for 10 days and service column lock turned on and shut down the car, it has had the recall done by gm, last nite went to the car wash and washed it, went to leave and same thing happened, first time i put in new battery and that worked. this time had to get rollback to pick it up . went to the garage where it was taken to and got in it to retrive some stuff and tryed to start it and it ran fine with no issues or message service column lock, any thoughts on this , dkrose54@yahoo.com
Old Sep 22, 2010 | 01:26 PM
8VETTE7's Avatar
8VETTE7
Do a search on "column lock" overr the last 2 or 3 weeks. There are probably a dozen threads on this subject that are that current. You can also read the first 2 pages and the last 10 pages of this thread:
http://forums.corvetteforum.com/c5-t...ky-please.html
And that is PAGES not posts.
You'll have all there is to know about this problem..
Old Sep 22, 2010 | 02:15 PM
dkrose54's Avatar
dkrose54
Originally Posted by 8vette7
do a search on "column lock" overr the last 2 or 3 weeks. There are probably a dozen threads on this subject that are that current. You can also read the first 2 pages and the last 10 pages of this thread:
and that is pages not posts.
if the recall was done and gm says it was , do i replace the harness they installed, or replace it with a coh harness, all i saw was questions with no real answers
Old Sep 23, 2010 | 11:14 AM
BigRobDsp's Avatar
BigRobDsp
Just install a column lock bypass. $50 will fix all of your problems. I had the same issue and have had many freinds with the same problem. You can do all the research you want and you will conclude that you need a CLB. the issue is one of voltage, and you can fix it by replacing batteries / cleaning the terminals / finding the short / etc... but just installing a CLB will fix your problem permanently.
Old Sep 24, 2010 | 07:28 AM
dkrose54's Avatar
dkrose54
thankyou very much, i will inform my shop and get it done
Old Sep 27, 2010 | 05:13 PM
redman0204's Avatar
redman0204
Default Clb
Just do the CLB . and you will sleep better at nighr .
To 97 vette column lock issue
