C5 cooling fan override
Old Sep 23, 2010 | 06:15 PM
rried2tall's Avatar
rried2tall
Default C5 cooling fan override
Do you guys know if anyone sells a cooling fan over ride kit for my 2003 vette, I noticed that West Coast Corvette has them for the C6 vettes. I would like to override the PCM and start the fans when I want to but still have the PCM do it's thing too.
Old Sep 23, 2010 | 11:13 PM
ZYBORG's Avatar
ZYBORG
There is a way to permanently keep the fans working for as long as you want when you want, the only down side is you have to actually get out the car, pop your hood, open the fuse box and put a wire in the connections where the fan relay goes and then the relay it self on top of that and voila! It will stay on and keep your car cool for hot laping at the track....
http://www.rangeracceleration.com/C5_Fan_Trick.html
hope this helps a little
Old Sep 24, 2010 | 12:17 AM
8VETTE7's Avatar
8VETTE7
Take a look at the product at this link:
http://www.saccitycorvette.com
Read the info there carefully. There are several products and you need to select the correct one for your car.
Old Sep 24, 2010 | 10:28 AM
rried2tall's Avatar
rried2tall
Default cooling fans
Thanks for the info. that is exactly what I was looking for, also looks like a good Corvette store.
Ron
Old Sep 24, 2010 | 03:40 PM
redrckt97's Avatar
redrckt97
Mid America carries a prrogrammable fan controller - part #612-069.
expensive though.
Old Sep 24, 2010 | 06:42 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Hi,
SacCityCorvette has the Cool it v2/v3 remote fan controller.
It allows you the to run both fans on lower speed with your C5
running or not or a single fan on high speed but the igniton has to be on. Its plug and play.
Here is the link.
http://www.saccitycorvette.com/COOLITv2.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
To C5 cooling fan override
