need some advice on oil pump o ring.
Old Sep 23, 2010 | 09:37 PM
20vette0107fatboy's Avatar
20vette0107fatboy
Default need some advice on oil pump o ring.
I'm in the middle of a Cam install and I put a new oil pump on. I also put a new pulley balanced on. My ques is, I used my old o ring in the new high flow oil pump. I forgot to put a new one in. I put it on the snout first lubed it real good and put it on strait. Sao you think I will be ok using the old one. It still looked good..... I wouldent have a problem taking my balancer off and putting the new one in but I don't know how I would get the balancer off. It don't have the three hole in it to put the pulley puller. Hopefully that o ring will be ok. Anyone else ever reuse there old o ring.
Old Sep 23, 2010 | 09:39 PM
ZeeOSix's Avatar
ZeeOSix
If it was in good shape it will probably be OK ... but of course a new one would have been the best route to go.
Old Sep 23, 2010 | 10:02 PM
Jnape's Avatar
Jnape
If it doesn't leak, you good to go. Pulling the balancer would be much more of an issue and you might still damage the new o-ring during reassembly...
Old Sep 23, 2010 | 10:17 PM
DIXZ's Avatar
DIXZ
I have reused mine a couple of times with no problem. It is not exactly the procedure I would recommend, but at 10:30 Sunday night, you do what you have to do!
Old Sep 23, 2010 | 11:00 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
if it wasnt cracked, dried, or pinched, its as good as a new one. if you were careful putting it on, your golden.
To need some advice on oil pump o ring.
