Will 295/45ZR-18 NITTOS work?!?
Old Mar 31, 2002 | 05:43 PM
johnso26's Avatar
johnso26
Default Will 295/45ZR-18 NITTOS work?!?
I am getting the Z06 repros in 18x9.5 and 18x10.5. Nitto has a 265/35ZR-18 for the front, but they only have a 285/35ZR-18 or a 295/45ZR-18 for the rear. Which would YOU recommend?! I know bparker ran the 285/35ZR-18 out rear and that worked out fine, but I was wondering if I could go with the 295/45ZR-18 without problems? The stockers are 275/40ZR-18. Will I actually create extra sidewall height?? I know there is something to the width and its relation to the sidewall.........HELP ME OUT!!! I don't want to screw up the speedo......... :cheers:
Thanks! :D
[EDIT]Here is Nitto's sizing chart...........
http://www.discounttiredirect.com/dt...=sizes&index=3
[Modified by johnso26, 3:44 PM 3/31/2002]
Old Mar 31, 2002 | 06:51 PM
C5 YA's Avatar
C5 YA
Default Re: Will 295/45ZR-18 NITTOS work?!? (johnso26)
275/40/18
sidewall 4.3"
radius 13.3"
diameter 26.7"
circumference 83.8"
285/35/18
sidewall 3.9"
radius 12.9"
diameter 25.9"
circumference 81.2"
295/45/18
sidewall 5.2"
radius 14.2"
diameter 28.5"
circumference 89.4"
Note I just added the specs for the stock rear tire (275/40/18)
[Modified by C5 YA, 5:52 PM 3/31/2002]
[Modified by C5 YA, 11:11 PM 3/31/2002]
Old Mar 31, 2002 | 06:57 PM
C5 YA's Avatar
C5 YA
Default Re: Will 295/45ZR-18 NITTOS work?!? (C5 YA)
285/35/18
speedo reading will be 6.7% too slow, so when you are going 60mph you will really be doing 64mph compared to the stock size [275/40/18]
295/45/18
speedo reading will be 3.0% too fast, so when you are going 60mph you will really be doing 58.2mph compared to the stock size [275/40/18]
[Modified by C5 YA, 11:07 PM 3/31/2002]
Old Mar 31, 2002 | 07:19 PM
johnso26's Avatar
johnso26
285/35/18
285/35/18
C5 YA,
WOW!! :eek: Thanks for the specs!! :)
I am assuming that what I highlighted above was supposed to be 295/45ZR-18?!? So, this would probably be the better choice since the speedo would be off by less (and LOWER) and I will have the extra width for more traction??? :cheers:
Old Mar 31, 2002 | 07:28 PM
c5 Lee's Avatar
c5 Lee
I thought I knew the answer to this one, but my answers keep coming up screwey.
I have heard all different kinds of ways to size tires. ( i.e. a lot of people including the tire stores did not know what all those numbers meant)
Here is my understanding.
In the tire size 275 / 40 - 18 , the first number represents the footprint size in mm. The second number is the aspect ratio. This ratio is expressed in % or the aspect ratio is 40% of 275 meaning that the sidewall height is 40% of 275. The last number is of course Inner diameter, or Rim size.
The problem that I have with that is that for our stock tires the sidewall would have to be 110mm which is 4.29 inches. I measured my sidewall and it is around 3.3 - 3.4 inches.
I really dont mean to answer your question with a question. Maybe the aspect ratio refers to uninflated tire size. Is there that much variation?
Sorry to confuse the issue. I know some of these guys here can clear this up.
Lee
Old Mar 31, 2002 | 07:30 PM
c5 Lee's Avatar
c5 Lee
Default Re: Will 295/45ZR-18 NITTOS work?!? (c5 Lee)
According to c5 ya 's numbers mine are correct.
c5YA. can you explain the discrepencies between the formula and actual measurements.
I have not been drinking. ...YET.
Old Mar 31, 2002 | 08:29 PM
johnso26's Avatar
johnso26
?? :confused:
Old Mar 31, 2002 | 08:46 PM
c5 Lee's Avatar
c5 Lee
Johnso26
dont let me confuse you. Believe it or not we are saying the same thing.
Go with his numbers and specs.
:cool: :cheers:
Old Mar 31, 2002 | 08:51 PM
johnso26's Avatar
johnso26
No problem........you didn't confuse me. :cheers:
I am just wondering if the 295 or the 285 is a better choice based on his calculations.
I would REALLY like pics of the ANY 295/45ZR-18 tire on a 10.5 in rim!!!! :yesnod:
I think I am going to make a new post.............. :)
Old Mar 31, 2002 | 09:09 PM
4DCYKEY's Avatar
4DCYKEY
In my opinion, a 295/45/18 will seem too tall for the Corvette. It is about 2 inches taller than the stock 270/40/18 and about two and a half inches taller than the 295/35/18 that most people run on the back of C5s...
Herb
Old Mar 31, 2002 | 09:14 PM
c5 Lee's Avatar
c5 Lee
Default Re: Will 295/45ZR-18 NITTOS work?!? (4DCYKEY)
I tend to agree with 4dcykey. I think that the 295 / 45 will be to tall a tire for the vette. Physically I think they will fit, I just like the low profile look better.
Let us know what you decide.
Old Mar 31, 2002 | 10:10 PM
johnso26's Avatar
johnso26
I agree with the 'too tall for the C5' thing......I just wanted to explore my options............ Thanks :cheers:
To Will 295/45ZR-18 NITTOS work?!?
