Sway bar end link ?
Old Sep 30, 2010 | 05:11 PM
thaitime's Avatar
thaitime
Default Sway bar end link ?
I need to replace the plastic sway bar end links on my 99 with the metal ones, Does anyone have any tips or a advice on doing this job, I am sure it's not hard just always like to ask here first..
thanks in advance
thaitime
Old Sep 30, 2010 | 05:23 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Its pretty easy. I got mad at mine and broke all the plastic ones. It didnt really help any but made me feel better. There isnt really much to say as far as what to do.
Old Sep 30, 2010 | 06:53 PM
thaitime's Avatar
thaitime
Do you lift the rear of the car up and take them both off at once or take of one of the wheels and do one at a time??
Old Sep 30, 2010 | 06:57 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
http://www.hotchkis.net/_uploaded_fi...795937file.pdf
Old Sep 30, 2010 | 06:59 PM
0331MARINE's Avatar
0331MARINE
I only had to take the front wheels off. I left the rears on whild I did the swap and just jacked the car up.
Old Sep 30, 2010 | 07:32 PM
thaitime's Avatar
thaitime
Thanks for the quick replies, I guess it's safe to say these end links aren't under any pressure that was my only concern, if I was to lift the rear was it going to put a load on the end links or lift the front was it going to put a load on them.?
Old Sep 30, 2010 | 07:44 PM
HowlinC5's Avatar
HowlinC5
The endlinks aren't under pressure but the sway bar will move some after you disconnect them. I did mine one at a time to limit the movement of the bar. I put my car on ramps and used the jack to support the a arm to make removal a little easier.
Old Sep 30, 2010 | 08:19 PM
Ultimate ride's Avatar
Ultimate ride
You might want to replace the sway bar bushings at the same time. An easy job.
Old Sep 30, 2010 | 10:05 PM
thaitime's Avatar
thaitime
I will definitely look into bushings as long as I am doing the end links, thanks for all the advice it's always a great feeling knowing I always get help here.
thanks all
Old Sep 30, 2010 | 10:43 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
thanks all
I might sell you mine because I'm looking at installing adjustable links. Mine are the factory metal links. Car is a garage queen with less that 30K miles
Old Oct 1, 2010 | 08:44 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
If anyone is looking to purchase new end links, let me know as I would be happy to help you out.
Old Oct 1, 2010 | 09:32 PM
lionelhutz's Avatar
lionelhutz
Either lift both sides or leave both sides under load. If you lift one side so it's hanging and the other side is still on the ground then the links would likely be under load.
Peter
Old Oct 2, 2010 | 11:26 AM
thaitime's Avatar
thaitime
Makes sense to keep equal pressure on the suspension.
thanks for the tip
Old Oct 3, 2010 | 05:54 AM
LS7.2's Avatar
LS7.2
The 2001 Z06 comes with plastic end links?? or what?
Old Oct 3, 2010 | 06:06 AM
RC45's Avatar
RC45
That is correct, '01's are plastic.
Old Oct 3, 2010 | 06:25 AM
LS7.2's Avatar
LS7.2
Thanks,
Mine is (too old) looking, it's time to change them to metal end links.
Old Oct 3, 2010 | 10:49 AM
imavettegirl's Avatar
imavettegirl
the fronts are metal the backs are plastic.
Old Oct 3, 2010 | 01:00 PM
lucky131969's Avatar
lucky131969
So you are saying they came from the factory, with metal endlinks in the front, and plastic in the rear ??
Old Oct 3, 2010 | 01:04 PM
0331MARINE's Avatar
0331MARINE
I have seen some odd stuff but not sure about that. My 01 had 4 plastic links on it.... I did a
C6 Z51 bar swap on a late 04 and it had a C6 rear sway bar on it.......
To Sway bar end link ?
