Help calculating DCR
Old Oct 1, 2010 | 10:31 AM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Default Help calculating DCR
I'm trying to calulate the DCR for 2 different cams and I think I'm doing it all wrong because I'm coming up with a 9.4:1 DCR.
The 2 different cam setups I'm trying to compare both use the same factory stock LS6 346cid longblock with the stock bore of 3.89 and stock stroke of 3.622, 10.5:1 SCR, the heads are stock 64cc ls6 heads and have stock 2.00/1.55 valves and use the factory .054 GM MLS headgasket.
I was trying to calculate the DCR difference between these two cams, 237/242 .603/.608 114LSA cam (110 ICL) and a 234/238 .598/.598 111LSA cam (109ICL).
Old Oct 1, 2010 | 11:13 AM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
I am on my work PC, but I have a calculator I found online on my home one, or id post it. Try to google one. Even then those arnt super accurate. Maybe call Scoggin Dickey or LME, A good builder and ask them to help you. with what you have there is NO way its 9.4. More like 8.4.
I racked my brain getting mine to where I wanted.
Old Oct 1, 2010 | 11:23 AM
manley845's Avatar
manley845
What is the spec for the Inlet Valve? What is the ABDC spec more specifically?
Old Oct 1, 2010 | 12:09 PM
manley845's Avatar
manley845
Using Comp Cams as a guide #54-446-11 232 @ .050" 71 degree ABDC I get 7.95:1
Old Oct 1, 2010 | 01:14 PM
Whistler's Avatar
Whistler
You need the seat to seat timing, not the .050 timing.... thats why your numbers are skewed.
Take the advertised duration, subtract the .050 duration from it and divide that in half.
That's the number to add to the intake valve ABDC timing to get the actual seat close timing.
Old Oct 1, 2010 | 01:32 PM
manley845's Avatar
manley845
I think rod length, and altitude will have an affect as well.
Just curious, what is the consensus about what is optimal for DCR?
Old Oct 1, 2010 | 01:48 PM
All_Motor_C5LS6
Ok, I think I'm about spot on with my calculations for the 234/238 cam (ICV 46 and 14*overlap). I came up with a 10.6 SCR and a 8.1 DCR...
I'm still trying to calculate for the 237/242 cam.
zeevette's Avatar
zeevette
Back when I did all this to select my first cam, the ideal was thought to be as close to 8.5:1 as possible.
Old Oct 1, 2010 | 02:01 PM
Whistler's Avatar
Whistler
Post both the advertised and .050 duration #s for each cam... as well as the intake centerline and the IVC (.050) ABDC I'll double check it for you.
Old Oct 1, 2010 | 03:35 PM
All_Motor_C5LS6
237/242 .603/.608 114LSA - Adv duration is 286/291 and ICV is 49.5 ICL is 111*
234/238 .598/.605 111LSA - Adv duration is 238/287 and ICV is 46 & ICL is 109*
Old Oct 1, 2010 | 03:55 PM
Whistler's Avatar
Whistler
Your IVC seat timing is 74 ABDC and your DCR is 7.81 with that cam, installed straight up.
Retard it 2 degrees and DCR drops to 7.67
Advance it 2 degrees and DCR increases to 7.96
Old Oct 2, 2010 | 03:50 PM
00Corvette's Avatar
00Corvette
lemme google that for ya. http://www.google.com/search?aq=f&so...tio+calculator
http://www.wallaceracing.com/dynamic-cr.php
Old Oct 4, 2010 | 09:07 AM
All_Motor_C5LS6
Thanks!
To Help calculating DCR
