ACA Lights No Low Beams
Old Oct 1, 2010 | 09:36 PM
sundayracer's Avatar
sundayracer
3rd Gear
Default ACA Lights No Low Beams
Just installed some ACA's. Fog's and Hi-Beams work great, but low beams will not come on.
Fuses seem to be good,even tried a different fuse in the breaker panel, also checked the connections.
Any ideas ?
Old Oct 1, 2010 | 09:39 PM
lucky131969's Avatar
lucky131969
Any ideas ?
Might have the connectors swapped, or they are pinned up wrong(very common with these wonderful Chinese kits). Give it a once over....
If all looks good, check for 12 volts and ground input to the ballast from the factory harness.
Old Oct 1, 2010 | 10:08 PM
sundayracer
3rd Gear
Tried reversing the plugs, same result except the headlight doors wouldn't close when the lights are switched off. I can hear the relay working when the low beam ACA socket makes contact with the factory harness low beam socket.
Do hi and low share a common ground ?
Old Oct 2, 2010 | 06:16 PM
sundayracer
3rd Gear
Problem Solved !! Thanks for your help.
To ACA Lights No Low Beams
