So even though C1221, C1222, C1225 and C1226 are wheel speed sensor codes and C1236 is a low voltage code and C1277 is a torque management code and C1282 is a yaw rate code and C1291/1293 are brake lamp codes,
If any of them come back your solution is to replace the EBCM?
Sorry,
I thought I caught a 1214 in there....
I stand corrected, fixed my original post. Thanks for the heads up!
The H suffix on all of those codes means that they are history codes. Clear them from your DIC and see if any of them come back after a little driving. Hold down the reset button while displaying any code within a module (ie. 28-tcs) to reset all of the codes in that module.
thanks much guys for all the info...I will take her out for another test this afternoon resetting it again...All this happened when i changed my shifter out last year. When the mechanic said his ratchet touched a hot wire near the traction control area creating a spark...Still one would think there would be a circuit breaker or fuse between there and the ebtcm
A huge thank you for everyones' input on my abs problem...I reset and erased all the codes and just yesterday took it for a test drivetc works and abs works .....no more codes or lit up icons in the dash.. so again, a whole bunch of kuddos to everyones posts seeyaGREG O.
