Headlight Adjustment
Old Apr 1, 2002 | 12:45 PM
BostonVette's Avatar
BostonVette
Default Headlight Adjustment
Anyone out there familiar with adjusting the elevation of the headlamps. I installed some Xenon charged lamps and while they are brighter, I noticed that they are aimed too low.
I found what appears to be a rod with a torx type end. Is this the adjuster? It does not want to turn, should it? I don't want to break it, Is it a lever? Is the adjuster somewhere else?
Lastly, does anyone know the set up spec for the low beams: height and distance from target?
Any info would be appreciated
Old Apr 1, 2002 | 01:01 PM
joeflyer's Avatar
joeflyer
Default Re: Headlight Adjustment (BostonVette)
Raise the headlamp doors, then turn off the lamps by turning the light switch to the parking-light position. Remove the plastic shields that surround the front and sides of the headlamps (3 screws each). Push the shield down to clear the bottom lip of the door, then pull it forward and up. This will provide access to the four adjusting screws (2 per lamp). These are brass screws facing toward the center of the engine compartment. They can be turned with either a T15 Torx driver or a 1/4-inch socket (one of my screws stripped out and the socket wouldn't fit, so I had to use small vise-grips). I suggest oiling all of the screw threads, because I could not turn mine until I did.
One screw on each side is just below the headlamp door behind the high beam. This screw adjusts the beam left and right. Turning the screw clockwise moves the beam toward the center of the car. The other screw is below and behind the first screw, and more difficult to get to. Raise the hood to access this screw. This screw moves the beam up and down. Turning the screw clockwise moves the beam down.
The high and low beams cannot be adjusted independently, so I just adjust the low beams and live with the high adjustment. I have the PIAA fog lamps, which are brighter than the high beams anyway. Leave the shields off until you are satisfied with the adjustments. Without a headlamp aiming tool, the best way to get the aiming correct is trial and error. Take the car out to a dark street or parking lot and see how the beams hit the asphalt. Adjust them to your liking. I like to have the beams point slightly inward about 75 feet out.
These aiming instructions were provided by SWCDuke:
"Find a flat area with a wall. (Parking garages are often good.) Measure the distance from the ground to the center of the headlight with the car at normal trim height. Place a couple of pieces of duct tape on the wall THREE INCHES below the level of your headlight centers, then position the car with the headlights 25 feet from the wall. Adjust the center point of the beam so it is straight ahead, then adjust the headlight pitch so that the cutoff is at the level of the tape, which will mean the beam drops 3 inches in 25 feet. This will provide excellent lighting and not blind oncoming drivers. While you're at it, check your foglight adjustment. Fogs have a flat cutoff and this should be at the same level (from 25 feet) as the center of the lens, in other words, parallel to the road at the same height as the center of the foglight lens".
Once you are satisfied with the adjustments, replace each shield by lowering it between the bumper cover and the bottom front of the headlamp, then pull it up, making sure that the plastic tab at the top goes between the door and the metal clip on the bottom side of the door.
Joe T
Old Apr 1, 2002 | 01:11 PM
BostonVette
Default Re: Headlight Adjustment (joeflyer)
Joe,
Thank you for the details, especially the aiming instructions.
I knew I could count on the forum to help.
Thanks again. Tom :cheers:
IMQUIK's Avatar
IMQUIK
:flag :D THANX MAN! I'll do it to mine tonight! :chevy
Old Apr 1, 2002 | 02:48 PM
Mad_Dog's Avatar
Mad_Dog
Cruise-In II Veteran
Cruise-In III Veteran
Thanks for the detailed instructions -- I need to adjust mine also. :D
Old Apr 1, 2002 | 11:40 PM
aces's Avatar
aces
Default Re: Headlight Adjustment (Mad_Dog)
The best advice it to junk the stock set-up and go to a euro set-up.
Old Jul 27, 2004 | 01:55 AM
pushc6's Avatar
pushc6
I just got back from adjusting my headlights, and I cannot for the life of me get the plastic shield back in place. I get it all on but over near the low beam the plastic sticks out a little like it wont go under and fit flush. If you run your fingers along the edge of the plastic piece it's all smooth with the guard and the top part of the headlight, but then you get to the low beam side and it's sticking out a little like it needs to be pushed in more but it wont move. Any tricks to getting that shield back in place easier? I literally just spent like 1.5 hours trying to get it back in place properly. It's like the cover needs to be shifted to the left, but every time i tried it did the same thing. And when I try to shift one of the set of holes wont line up properly. This is extremely frustrating.
Old Jul 27, 2004 | 02:08 PM
Blue50th_Racer's Avatar
Blue50th_Racer
...and bump the wattage of the H4's up a notch to 90/135w - absolutely fabulous solution.
Old Jul 27, 2004 | 02:18 PM
Mike04's Avatar
Mike04
That's what I'm running
Old Jul 28, 2004 | 12:03 PM
Blue50th_Racer
Are you sure you didn't switch left and right shields?
Sorry, my memory on these is poor and I'm on the way out the door, else I'd pop one off and check. I remember that there are clips that need to slid either on or into to keep the top edge seated. Perhaps one is not seated?
To Headlight Adjustment
