coolant tank question
Old Oct 9, 2010 | 09:02 AM
v1 rot8's Avatar
v1 rot8
Default coolant tank question
I am considering changing my 98 coolant tank with a 2001 painted coolant tank. The 97-99 coolants tanks had a coolant level sensor, the 2000-04's did not. Does anyone know if I will have a constant "Check engine" / "Low level coolant" warning if I change and if so is there an easy way to stop the warning?
Old Oct 9, 2010 | 09:06 AM
lucky131969's Avatar
lucky131969
Jumper the connector for the sensor.
Old Oct 9, 2010 | 09:15 AM
v1 rot8's Avatar
v1 rot8
you mean where I unplug it from my tank,,, jumper the plug so it thinks it is still connected to the tank?
Old Oct 9, 2010 | 09:18 AM
lucky131969
If you look in the instrument cluster schematics, it shows the coolant level switch, and states.....the switch is closed(providing a ground) to the IPC, when the coolant level is full. So by jumpering the connector, the IPC thinks the coolant level is full.
Old Oct 9, 2010 | 09:20 AM
v1 rot8's Avatar
v1 rot8
ok, got it. Thanks
To coolant tank question
