Difference between front and back tires
Old Oct 9, 2010 | 08:08 PM
Irish Whiskey's Avatar
Irish Whiskey
Default Difference between front and back tires
If the total diameter between the front wheel/tires and the back wheel/tires excedes the allowable difference, I know the speedometer will be wack - what else goes wack, ABS???
Old Oct 10, 2010 | 08:36 AM
99 vett babycar's Avatar
99 vett babycar
if the difference is large enough the car will go into Reduced Power Mode.
Old Oct 10, 2010 | 08:40 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
If the rear tires are the same diameter or smaller than the front your traction control system will activate at very inopportune times. Generally speaking you want to keep the rear wheel/tire combo 1/2 to 1 inch taller.
Old Oct 10, 2010 | 09:21 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
The car's onboard computer looks to see the difference between the car's front wheel RPM and rear wheel RPM. There is a specified difference that the computer expects to see. If that expected difference in wheel speeds is exceeded, the computer then calculates it as either "skidding" or "excessive wheelspin", and engages either the ABS, Traction Control, or the Active Handling, in order to resolve the "problem".
In your example, with the rear tire's OD being "too small", the computer preceives this as "wheelspin", and the traction control activates, reducing power, until traction is achieved. However, since the tires are the cause, and a constant, the problem can't resolve, so you'll be in reduced power mode all the time.
Old Oct 10, 2010 | 04:44 PM
vetteman741's Avatar
vetteman741
From: Motorsports Capital of the World..Indianapolis Indiana
makes me wonder if the moron I saw with gold 20" donks all around on his C5 has problems
To each their own,
Old Oct 10, 2010 | 08:56 PM
m6 c5's Avatar
m6 c5
If the rear tires are too small then you can just turn off traction control and drive normally, but its not a good idea to do this unless its only temporary.
Old Oct 11, 2010 | 07:22 AM
leadfoot4's Avatar
leadfoot4
To each their own,
Of course he has problems...beginning with his desire to have 20" gold donks on his car!!
Old Oct 11, 2010 | 03:36 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Read my post on the subject. It should help...
http://forums.corvetteforum.com/c5-g...ah-issues.html
Toque
Old Oct 11, 2010 | 03:46 PM
Hamze's Avatar
Hamze
Got 20's on all 4 corners since 5 yrs now with zero issues! also got 19's all around on my previous c5 for also 5 yrs... no issues at all!
Old Oct 11, 2010 | 09:45 PM
vetteman741
Default my bad
They look good in that color wheel, do you have different size tire diameter f&r, do they rub....ever
Nice body kit too
Old Oct 12, 2010 | 12:00 PM
Hamze's Avatar
Hamze
Nice body kit too
Thank you bro!
rims are 9.5' wide .. front tires are 255 35 20 , and the rears are 275 35 20. The fronts rub a little when i go over a speed bump only. i will fix the issue when i install my tpe t2 flares, i will install lower profile tire at the front and 345's at the rear hopefully
To Difference between front and back tires
