descreening maf with vararam
Old Oct 10, 2010 | 06:08 PM
robert21122's Avatar
robert21122
Default descreening maf with vararam
would it be ok if im running a vararam intake to descreen my maf and maybe adding 75 or 100 dry shot and how do i do it or shuold i say what tools
Old Oct 10, 2010 | 06:28 PM
ZZ06's Avatar
ZZ06
you know i spoke with my mechanic about descreening and he recommended against it. It really changes that flow over the MAF and sometimes can cause a rough n low idle. You would be doing this with vararam and i dont think your PCM will like it to much. It already has a hard enough time makin the AF ratio adjustments with the MAF screen in. Im sure somone with more experience then me will chime in about the N20.
Old Oct 10, 2010 | 10:51 PM
rebelheart's Avatar
rebelheart
The increased airflow with a Vararam seems to cause more turbulence without a screen.The ZO6 folks run into this problem.
To descreening maf with vararam
