When is the engine warmed up?
Apr 1, 2002 | 09:22 PM
Navigator
Hi all,
What would be normal oil and coolant temps when the engine is "warmed up"?
thanks,
jeff
_____________________________
We want it all. So we will need quite a lot...
:flag
Apr 1, 2002 | 09:31 PM
Re: When is the engine warmed up? (qbolyf)
I look at the oil temperature as an idication of "warmed up". When it hits 180 you are safe to go WOT! :cheers:
Apr 1, 2002 | 09:56 PM
Re: When is the engine warmed up? (Viprklr)
after WOT, it's warmed up:) j/k
Apr 2, 2002 | 02:09 AM
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I concur wholeheartedly!
Apr 2, 2002 | 08:23 AM
oil temp @160 = warmed up
Apr 2, 2002 | 08:27 AM
Re: When is the engine warmed up? (Skeeter1)
Call me ****, but I wait till the oil temp is above 100 degrees before I even tach it up past 2000 rpms. After 150 degrees, WOT should be OK.
Apr 2, 2002 | 12:07 PM
Re: When is the engine warmed up? (MiamiDave)
My car does not move until the Oil Temp hits 100, then creep along until it reachs 150.
MRR
Apr 2, 2002 | 02:52 PM
Re: When is the engine warmed up? (MRR2)
I'll go 3000 rpm under 150 degrees oil temp, once it hits 150 I'm WOT.
I used to go by water temp in my old 93 Trans Am and I'm really glad the C5 has oil temp.
Apr 6, 2002 | 07:38 AM
St. Jude Donor '10
Oil to 190 degrees. Then I begin stomping it! :eek: :eek:
Apr 6, 2002 | 08:32 AM
From: My barber didn't know when to quit... Do you?
Same here!!!
Apr 6, 2002 | 09:25 AM
I guess I'm the odd man out here. 100 degrees oil temp and she is ready to run. Until the weather is over 80, my oil temps never go over 150, the DRM oil cooler sees to that. We are running synthetic oil, it's not like the old days. As far as I'm concerned, if the thermostat is open, so is the throttle.
Apr 6, 2002 | 11:47 AM
Re: When is the engine warmed up? (2000^C5)
[QUOTE]I look at the oil temperature as an idication of "warmed up". When it hits 180 you are safe to go WOT![QUOTE]
