New owner
Old Oct 11, 2010 | 05:43 PM
Larry W Dennis's Avatar
Larry W Dennis
Default New owner
I just bought a 1998 corvette convertable. There is a switch next to the steering wheel colume and I cannot figure out what it does. It is next to my ignition switch also. The owners manual does not address this switch. Can someone advise. Thanks
Old Oct 11, 2010 | 05:51 PM
J T's Avatar
J T
IB Staff
You had posted your question in the Help section, which is used for Help with the website itself (forum issues, account issues, website issues, etc.).
You will receive a better response if you post Corvette technical questions in the appropriate Corvette section. In your case, you would want the C5 Tech section.
I've moved your thread to the appropriate Corvette section.
Good luck!
Old Oct 11, 2010 | 05:59 PM
RedZMonte's Avatar
RedZMonte
Got a Picture? not sure i have a switch where your refering to... is it a OEM style switch or something that appears added?
S
Old Oct 11, 2010 | 06:07 PM
Larry W Dennis
S
No pic, it is next to the ignition switch, it is Factory. On top of the switch there is like a small vent.
Old Oct 11, 2010 | 06:31 PM
m6 c5's Avatar
m6 c5
I dont recall seeing a switch but the vent has to deal with your climate control, the thermometer is behind it to determine when to turn the ac on/off. There is also a sensor on your dash that determines how much sun is coming in to the car which also plays a factor on how the ac operates.
Old Oct 11, 2010 | 11:58 PM
cdkcorvette7's Avatar
cdkcorvette7
Are you talking about two switches or the same switch? To the best of my knowledge, there is no OEM switch next to the ignition. This would be a lot easier if you would post a picture of it...
If for some reason you can't post a picture, can you describe it in a little more detail? Is it a rocker style switch?
Old Oct 12, 2010 | 11:37 AM
m6 c5's Avatar
m6 c5
It sounds like there is a switch above the vent for the ac where there is a blank space on the cover.
Old Oct 13, 2010 | 12:26 AM
98vette4ever's Avatar
98vette4ever
I have a mid year 98..
I don't have a switch in that area... Hmmmmm
Do you have any pictures?
Old Oct 13, 2010 | 12:49 AM
cdkcorvette7
A picture would make this really easy to answer...
Old Oct 13, 2010 | 09:27 AM
rebelheart's Avatar
rebelheart
Perhaps he is talking about the switch on the column that moves the steering wheel in and out?
To New owner
