Pcv ?
Old Oct 11, 2010 | 08:26 PM
thaitime's Avatar
thaitime
Default Pcv ?
I have a 1999 coupe and took of the fuel rail covers and not quite sure where the PCV? is located on a 99 I would like to check/replace if necessary the car has 79,000 miles on it please any ifo or pictures much appreciated. also I have read about catch cans, I might also do this but for now would like to check valve.
thanks in advance
Old Oct 11, 2010 | 10:42 PM
robsc501's Avatar
robsc501
Hi There,
This should help you out.
http://www.conceptualpolymer.com/PCV...eplacement.htm
robsc501
Old Oct 12, 2010 | 11:51 AM
thaitime's Avatar
thaitime
It looks like the hyperlink is no longer available.
Old Oct 12, 2010 | 07:23 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The pcv is located at the right forward head, mounted horizontal and feeds the throttle body on the right side. It should be held up by what looks like a large ground wire but really isn't that...steel cable for heat transfer.
Old Oct 12, 2010 | 07:32 PM
warpster's Avatar
warpster
Try here...
http://www.conceptualpolymer.com/Ins...20Corvette.pdf
Old Oct 12, 2010 | 08:11 PM
robsc501's Avatar
robsc501
Hi There,
The Warpster has it right. Page 6 green arrow is pointing to it. Its inside that hose. Tough to pull out.
robsc501
Old Oct 12, 2010 | 11:23 PM
thaitime's Avatar
thaitime
Great stuff thank you so much for the help warpster it's true a picture is worth a thousand words.
To Pcv ?
