TPMS Battery Life
Old Oct 12, 2010 | 12:08 AM
saetta's Avatar
saetta
Default TPMS Battery Life
2000 Coupe w/Magnesium Wheels. There MUST be a way to test or determine how much longer the TPMS batteries will last. Why replace them if I still have two or three years left? The car was built in August '99 and has 65k on the odometer. Getting ready to install the fourth set of tires since the car came from Bowling Green and would rather not spend the $200 at this time if I can help it. Has anyone found a way to test the remaining battery life?
Old Oct 12, 2010 | 12:25 AM
jcgunn's Avatar
jcgunn
This is easy--buy new ones from Gene. Sell the old ones on that auction site for about $69 then you are good to go for 8-10 more years
Old Oct 12, 2010 | 03:06 PM
MG RED 99's Avatar
MG RED 99
The only way to test them is when the DIC stops getting a reading, but then it's to late. My suggestion is to replace them with the next tire change.
Old Oct 12, 2010 | 05:17 PM
C5at57's Avatar
C5at57
TPS batteries last about 8 to 10 years depending how much you drive the car. You can also buy them at Costco.
Old Oct 13, 2010 | 11:36 PM
saetta's Avatar
saetta
While I see, and am grateful, for the logic in the responses, my question dealt with testing the remaining life in the TPMS transmitter batteries. With all of the technology available to the best damned sports car ever built, it will be difficult for me to except as fact that there is no way to measure the battery life still available in the transmitters. If my tires were in good condition and didn't need replacing a gadget to test the batteries would be a good investment. Maybe invent-a-tool.com can help. The search continues.
Old Oct 14, 2010 | 12:23 AM
3rd_Vette's Avatar
3rd_Vette
OK.. Im confused... Are we talking about the pressure censers in the wheels? If so, i asked the girl at Corvettes of Houston today if there were batteries in them and she said no.. They just need to be "programed" when you replace your tires. OK, if Im wrong, someone correct me.. Im also told that they are a bit expensive to replace.. Ugh...
Old Oct 14, 2010 | 01:03 AM
Corvette Don's Avatar
Corvette Don
I can rebuild them, pm me for details
Old Oct 14, 2010 | 05:56 PM
C5at57's Avatar
C5at57
Sure you can test the batteries inside the sensors. Just break down each wheel, remove the sensor from the wheel, drill a small hole into the sensor down to the positive and negative terminals on the circuit board, then using a DVM (digital volt meter) measure the battery voltage. You should read about 3VDC. Not trying to be sarcastic, but like they all said, there is no simple way to test them. You just wait for them to die and replace them. There is a "HOW TO" post here on the forum so you can do it yourself. It even tells you the battery number, where to buy it and it's not that hard. PM me if your interested and I can give you some hints to make the job easier.
Old Oct 14, 2010 | 06:13 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Originally Posted by 8VETTE7
It is about a wash $$$ wise to buy 4 new early year sensors or do the upgrade.
Not hardly. You can buy four new '97-'00 sensors from Tire Rack for $252.00 plus shipping. Doing the conversion with sensors, receiver and FOB will be around $400.00.
Old Oct 14, 2010 | 07:02 PM
SPS's Avatar
SPS
I say don't replace them until they stop working. I got my car in October of 97 and the rears are still doing fine. ( I trashed my front sensors putting goop into the tires trying to fix slow leaks from aftermarket chromed wheels that were corroding - had to put the old wagon wheels back on.....errggg!)
Old Oct 14, 2010 | 11:09 PM
MG RED 99's Avatar
MG RED 99
Our corvette society just isn't that advanced yet. If there is a way to test battery life through thin air then I've never heard of it. No wires of anykind means no way of testing. You can either be proactive in changing them while all the tires are broken down or just replace each one as they fail. That's just how TPMS works and that goes for any car with them.
Old Oct 14, 2010 | 11:16 PM
3rd_Vette's Avatar
3rd_Vette
OK... Time to change the subject.. Mine are still the 12 year old originals (I talked to the original owner today) and I don't want to jinx mine until I replace my wheels and tires next spring
Old Oct 15, 2010 | 10:41 AM
saetta's Avatar
saetta
To all of my Corvette brothers and sisters, thank you for all of your help in trying to solve my dilemma. It seems technology has once again answered the question. ATEQ makes a series of testers that can indicate various states of TPMS battery condition. While that is good news the caveat is this: the testers cost about the same as a set of new sensors! ATEQ does have a list of service providers by zip code that have the testers and will check the status for a nominal fee. I called the USA office in Michigan and they were quite helpful. Time to solve the next problem. Let's find a 1.5 DIN nav system that's not motorized and doesn't require a $400 modification to the center stack bezel. Ready, set, GO....
Old Oct 15, 2010 | 12:48 PM
HeadsUp's Avatar
HeadsUp
I was in the same dilemma earlier this year. Decided to upgrade the system to 2001+ parts since both my fobs were dead also. You could order the parts from PartsTaxi.com. The total (less shipping) is $350. Had a problem with the reciever being in stock so I went the e-b-a-y route for the receiver and fobs. Cost was about the same and it worked no problems. Send me a PM and I'll send you a link of a current auction.
Then you can put the old parts on the forum for sale. Just got back more than half of the $350 re-couping much of the cost.
Old Oct 15, 2010 | 02:01 PM
saetta's Avatar
saetta
Believe it or not, local classic auto dealer advises, that as long as I have the factory Magnesium wheels, I'm better off sticking with the original style sensors. Something to do with future resale value. Go figure.
To TPMS Battery Life
