need help
Old Oct 12, 2010 | 08:20 PM
fsuforever's Avatar
fsuforever
Default need help
I was told from a shop that I couldn't get ball joints without the control arms,did it use to be that way ? I see that I can buy 1 ball joint or 8 ball joints without the control arms, so we have 4 for the rear & 4 for the front? is this codrect ?where's the cheapest place to get them,iappreciate feedback on this very much ,thank u
Old Oct 12, 2010 | 08:44 PM
Paul 75 L82's Avatar
Paul 75 L82
I don't know but I would call Gene at GM Parts House.
Old Oct 12, 2010 | 09:22 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Interesting that one of the major Corvette suppliers lists ball joints for @ $60 and then says
"1997-2004
C5 Corvette upper & lower ball joints have been hard to find, namely because they are deemed as a non-serviceable item from GM. After years of road use or hard turns on the track, your Corvette's front suspension become real loose, causing inconsistent handling and aggressive tire wear. "
To need help
